Old 07-31-2010, 02:37 AM   #1
jenny1
Move O/S Partition To New Drive
Hello Everybody.
I broke down and ordered an Intel SSD today from Newegg. I presently have a Raid0 setup which is split into 2 partitions. Win 7 is installed on the C partition. I would like to clone only that partition to my SSD. Can anybody recommend a process and the software needed to do this.
Thank You.
___________
Old 07-31-2010, 02:39 AM   #2
jenny1
Re: Move O/S Partition To New Drive
Ok good......
________________---
Old 07-31-2010, 07:42 AM   #3
If it were me, I'd do a clean install after saveing everything I could to DVD's to put back on post install.
Old 07-31-2010, 08:43 AM   #4
DBoone
Just call me Dave
DBoone's Avatar
Water cooled rig - Obsidian 800D, Corsair HX750, Sapphire 5570, Asus Rampage III Extreme, Intel Core I7-930, 6GB Corsair Dominator PC3-12800 (DDR3 1600) memory, Windows 7 Pro
Old 07-31-2010, 12:00 PM   #5
klc314
I've used Acronis Migrate Easy several times with good results
Old 08-01-2010, 01:58 PM   #6
Acronis True Image Home 2010 should work just fine.
Old 08-01-2010, 02:18 PM   #7
I know its a pain but your way better off doing a clean install and make sure you set it to ACHI in the bios for TRIM to work on your new Intel SSD!
