Old 09-22-2010, 02:23 PM   #1
xbwfo
xbwfo's Avatar
Bootable XP CD with Defrag
Hi all, it's been a while
I would like to find a free D/L of a bootable cd (ISO or something) that has a defrag function on it that will work on a dell dim4600 w/ xp sp3.
ASUS P4C800 Deluxe
P4 3.0@4030 - 7000cu w/120mm panaflo
1 Gig Corsair PC3700 1:1 3,3,4,7,8
Old 09-22-2010, 06:35 PM   #2
Re: Bootable XP CD with Defrag
Ultimate Boot CD - Download the UBCD
Old 09-22-2010, 07:17 PM   #3
rjs735
Virus? What I am not sick
rjs735's Avatar
there are 2 version the UBCD which uses a Linux base and then there is the UBCD4Win which is a windows based solution. Both or either will work.
Optorite CDRW WD 40GB
All systems are networked
Old 09-24-2010, 12:14 PM   #4
xbwfo
xbwfo's Avatar
Thanks guys, just what I needed.
ASUS P4C800 Deluxe
Old 10-10-2010, 01:43 AM   #5
What does a Bootable XP CD With Defrag do ? It helps to defrag your C: Drive's unmovable files too is it ?
