Old 08-21-2011, 04:11 PM   #1
Scoundrel
Ferrari....hah!!
Scoundrel's Avatar
Recommend a good cheap Z68 SLI board
EDIT: Sorry! should have made this post in the Intel forum...
Hi Guys,
I'm looking for a good & cheap Z68 motherboard for my i7 2600K and ASUS nVidia GTX 560TI.
I'm not planning on overclocking the CPU or graphics, but i want to be able to play Battlefield 3 on my Dell U2711 monitor at 2560x1440 so i guess the cheapest option would be to get another 560TI and a supported motherboard. (i have a intel H67CL now)
On the spec-list of many board i have checked out, the 2. PCI-X slot are often NOT running the same speed as the primary one....I'm not sure if that's an issue, but i'd rather pay a little more for one running at at full 16x if it makes a difference at all.
There are so many different versions of what to me looks like the same boards, and maybe the differences are only important for OC'ers looking to squeeze out every last mhz of an overclock. But I just want stability a default speed.
Can you recommend me a good board for my needs?
BR - Scoundrel
Old 08-21-2011, 05:19 PM   #2
Re: Recommend a good cheap Z68 SLI board
http://www.newegg.com/Product/Produc...82E16813128502
Old 10-25-2011, 04:04 AM   #3
roncalion
Take a look at the ASUS P8Z68-V.
