Old 10-08-2011, 03:15 AM   #1
New ASUS Motherboard
I bought a new Asus Motherboard. I recently had an intel original motherboard running my dual core 3.4 Ghz. And it was extremely noisy. Now i finally replaced only the motherboard with the same old processor and heatsink and what a world of difference it made. Now the system runs extremely silent. I however have some small roadblocks with the current new motherboard ASUS G41.
I was hoping members here could help me out.
The problem is that the external Modem which i use is connected to the usb port for its power. This is a boon for me as when i have the system doing a download and i set the system to shutdown after the download, the system would shut down and hence also cut off power to the modem. I wont have the modem running all thru the night and warming up unnecessarily.
But now with this new motherboard im perplexed because even though the system shuts down the modem is still being powered and running on till the morning. Is there any windows or BIOS setting i can use to deactivate this feature ? I mean how can a system thats fully shut down still be supplying power to the modem ?
Old 10-08-2011, 08:48 AM   #2
Re: New ASUS Motherboard
Maybe some USB ports remain powered when the system is powered down and others don't? Try a different port.
Old 10-08-2011, 08:52 AM   #3
Update the BIOS?
Old 10-08-2011, 01:11 PM   #4
Its a new MB. Just 3 days old. So i was sorta reluctant to tamper with the BIOS. But my keyboard is connected to another usb port and that doesnt receive power after the system is off.
Maybe that port isnt receiving power. So maybe a swap of ports should work ? Ill try that right away and report back. Thanks guys.
Old 10-08-2011, 01:56 PM   #5
Hi Vik,
Go into the BIOS settings, and within the "Power" related settings you'll probably find something called "APM" (Advanced Power Management), or something like that. Within that there will probably be a setting to enable or disable allowing an external modem to start the computer. If it is presently set to "enable," change the setting to "disable" and that should resolve the problem.
Best regards,
Old 10-09-2011, 02:15 AM   #6
Hey Ctal !!!!! How are you !! Its been a while.
Thanks for the tip. Will try that right away.
Warm Regards
Vik
Old 10-09-2011, 06:56 AM   #7
Just an update. I tried both a different port and the bios setting was already at disabled for APM. Both options are still supplying power to the usb port. Thats a pain. Which means ill have to wake up midnights to switch off just the modem. After downloads etc.
Any other bizzare ideas i can try ? Any jumpers on the board or something ?
Vik
Old 10-17-2011, 12:14 PM   #8
Drufuss
Drufuss's Avatar
Originally Posted by plainman007 View Post
Vik
I remember that sometimes there are just BIOS options to enable powered USB-ports when pc is shutdown, and sometimes there are jumpers to be set. IN my case i think there are some jumpers.
Greetings
Dru
System specs:
Asus Maximus VI Formula (watercooled)
Core i7-4790K 4.00 GHz (watercooled)
4 x 8GB DDR3-Ram PC3-2400 Kingston Beast XMP
3 x Samsung 840 EvoO 1 TB
Gigabyte GeForce GTX970 G1 Gaming (watercooled)
Soundblaster ZxR, Hauppauge HVR4400 DVB-T/S2, Logitech Z-5450 5.1 THX Wireless
Logitech DiNovo MediaDesktop 2.0
Enermax Platimax 750W
Pump: Laing DDC2
Radiator: Watercool Mo-Ra 3 420
Case: Cooltek Antiphon
Windows 7 Ultimate 64bit retail
CUSL2-C ruled! ..äh... RulEd!
Time flies like an arrow,
fruit flies like a banana.
Old 10-18-2011, 08:34 AM   #9
You can try disabling Legacy USB or try setting your wake state to S0 in BIOS.
