Old 11-13-2011, 03:16 AM   #1
hansje
hansje's Avatar
Windows 7 VS XP...F1 2010 Codemasters
Just installed F1 2010 Codemasters, same install with graphic settings at Ultra.
See my system..sign.
At the start of a Race:
Windows 7 >> 36 FPS
XP >> 74 FPS ....and the winner is
XP still seems the better gamesystem, ofcourse not in every game
Strange because Windows 7 sees 4 sticks of memory and XP less...correct me if I am wrong !?
If you get bad FPS its still worth to install the good old XP version !!
Nice sunday
Hansje
Game/System: Processor Intel Core i7 2600K (4.6GHZ) - Asus P8Z68-V PRO - Corsair Vengeance LP 2X4096MB DDR3 1600 - Evga 580GTX - Soundblaster X-Fi Xtreme Gamer - 2X Seagate 320 GB
Philips 247E LPH - Enermax 600 Watt - Dual boot XP with Windows 7.
Old 11-13-2011, 05:10 AM   #2
WolfSoul
WolfSoul's Avatar
Re: Windows 7 VS XP...F1 2010 Codemasters
Xp 32 bit and 7 64 bit probably.. that would explain the memory thing
Cooler Master Storm Trooper/Silent Pro Gold 1000 W
Asus Rampage III Extreme - Intel I7-960 - 4 X 4 GB Kingston DDR3-1600
2 X 256GB Samsung 830 - 1 TB WD Velociraptor - 2 X 2 TB WD Caviar Black - 2 TB Seagate Sata III Barracuda
LG BH10LS38 BluRay Burner - Plextor PX-L890SA DVD Burner
Creative X-Fi Titanium Fatality Champion - Gigabyte GTX 670 WF OC 2GB
Dell U2412M - Logitech Z-5500 5.1 Surround System - Creative Tactic3D Wrath
Logitech G19 Gaming keyboard - Logitech G9X laser Gaming Mouse
Old 11-13-2011, 05:53 AM   #3
hansje
hansje's Avatar
Is Windows 7 more demanding...more things running in the back and so on ?
Wonder if more guys around are using XP for gaming...can't be the only one
Keep this dual-boot, its worth to keep XP for a while.
Thanks for your reply.
Nice sunday
Hansje.
Old 11-13-2011, 05:55 AM   #4
WolfSoul
WolfSoul's Avatar
No if your 7 is 64 bit it will recognize more memory
A 32-bit OS can only read a little less than 4 RAM
I could go dig up the more expanded technical explanation
Nie echt een zondag persoon
Old 11-13-2011, 06:03 AM   #5
hansje
hansje's Avatar
Hahaha !! dan wens ik je een prettige maandag
Sorry guys, its dutch
Hansje
Old 11-13-2011, 06:21 AM   #6
Nice sunday
Hansje.
That is correct and yes a lot of gamers are on XP for that very reason. I modify Win-7 by shutting off a lot of services or should I say disable them. Go to black vipers web site for details on which services you can disable. http://www.blackviper.com/
Old 11-13-2011, 04:16 PM   #7
WolfSoul
WolfSoul's Avatar
Did you happen to enable vsync on the 7 version.. vertical sync tends to cap your FPS (usually to 30 or 60)
Old 11-14-2011, 02:54 AM   #8
hansje
hansje's Avatar
Thats funny I just visited Black-vipers Website...I did this a lot in the past with Windows 98SE ...thanks for the link anyway.
In F1 2010 you can enable of disable Vsync, and I am using FRAPS to see my FPS...did more tests but XP seems the better game-system.
See you guys
Hansje
