Old 04-12-2012, 10:17 AM   #1
Razorback
Reinstall Question
I have a friend at work that had a "ransom" virus get on his machine. He took it to someone to have it looked at and they said they removed the virus. He took the PC home and it would not boot. I took a look at it and it booted fine at my house. He took it back home and got some SMART HDD error popups. I have attached them. I was able to launch programs and do normal functions on the PC with no issue. I did not, however, connect to the internet at my house. When he clicked on checking or repairing the hard drive, it kept coming up with a message for a credit card. I have never heard of a ransom virus but the original guy that removed the virus said it was common. So, are these viruses legit and difficult to remove? And should I help him re-install the OS back to when he got it from Dell? Thanks.
Old 04-12-2012, 12:19 PM   #2
Re: Reinstall Question
Do a reinstall, that is the virus in that second picture, I'm pretty sure! Has soon has who ever clicked "run scan" he installed the virus!
Old 04-12-2012, 03:44 PM   #3
Yes, that is almost certainly a virus. Before doing a re-install, though, it would probably be worthwhile to first try booting in safe mode, and if possible doing a system restore to a date prior to when the problem arose. Then running a full anti-virus scan if that appears to fix the problem.
Old 04-12-2012, 04:23 PM   #4
Also run malware bytes at the same time after the anti virus!
Old 04-12-2012, 05:44 PM   #5
SpeedDMN
Silicon Avatar
SpeedDMN's Avatar
Yeah definately sounds like one of those nasty "redirect" viri. The best antivi that I have used for that is Spyware doctor. If that doesn't kill it nothing will. Even the painstaking step by step registry fixes don't seem to work often. Sometimes it's just better to just format and be done with it. I have found saving all your docs and such does not seem to transfer the virus back. At least it hasn't for me ever. Also separate storage drives don't seem to transfer them back to the newly formatted drive either. My mom has something similar on her machine. I have fought with it a few times. You think you got it licked and bam, there it is again.
Oh and I don't recommend Spyware doctor for your everyday scanner. It's a resource hog and annoying with all the pop ups.
Core i7 2600k (Sandybridge) @ 5.0g/ Corsair H-100 liquid CPU cooling / Asus P8Z68 Deluxe
Radeon HD R6850 MSI Cyclone X2 Xfire stock / Windows 7 Ultimate x64 / Realtec onboard sound
Corsair Vengeance 4 x 2g DDR3 @ 1600MHz / Corsair TX850 PSU / LG bluray player + burner/ OCZ Vertex 3 SSD 120g (system) + 450g WD velociraptor, Seagate 1.5t (storage)
Old 04-12-2012, 06:17 PM   #6
Razorback
Thanks guys! I was leaning toward a re-install since he is not real tech savvy. Sounds like he had someone do battle but did not get it fully removed.
