Old 09-22-2012, 11:17 PM   #1
mindx2
mindx2's Avatar
Question Something strange happened?!
I keep my rig on all the time and when I went to use it the screen was black with the message: BOOTMGR missing. My first thought was that my SSD had crashed but when I went into the BIOS I found the boot order had changed from booting from my SSD to one of my storage drives. I changed the boot order back and everything restarted fine (well it went to the windows screen asking if I wanted to boot into safe mode). Has anyone had this happen to them before? Should I be worried? My rig is in my signature.
Thanks.
Edit: Alright, something is seriously wrong with my system. Everything froze on me and it crashed to blue screen. After rebooting my SSD went missing in my BIOS. After rebooting several times it shows back up in my BIOS and I switch the boot order again. It then boots up fine, going straight to the windows safe-mode page. I'm worried my Crucial M4 is dying. How can I check to find out if it is? Is it easy to transfer everything over to one of my storage drives "just in case" I need a new system drive just to start my computer?
ASUS P8Z68-V Pro GEN 3 / Intel Core i5-2500K Sandy Bridge 3.3GHz / CORSAIR Hydro Series H100 / G.SKILL Ripjaws X Series 16GB (2 x 8GB) / 2 x EVGA 2GB GTX 560 PCI-e / Crucial M4 2.5" 256GB SATA III / WD VelociRaptor 500GB / 2 Western Digital Green 500GB SATA / Creative X-Fi Fatal1ty PCI-e / SAMSUNG Black Blu-ray Combo SATA / NZXT Phantom 820 Matte Black Steel ATX Full Tower / CORSAIR HX Series HX750 750W / ViewSonic VA243wm LCD / Windows 7 Home Premium- 64
Old 09-23-2012, 12:10 AM   #2
Re: Something strange happened?!
Originally Posted by mindx2 View Post
I keep my rig on all the time...
Maybe a glitch in the house power? I'd guess if there was any kind of drop or spike the system might take a hit. Did you check the disk for any errors?
Old 09-23-2012, 12:19 AM   #3
mindx2
mindx2's Avatar
No issues with power. What's the best "free" program to check SSDs for errors?
Old 09-23-2012, 01:57 AM   #4
What about CHKDSK? Are you running Windows?
Old 09-23-2012, 07:06 AM   #5
mindx2
mindx2's Avatar
I've read that CHKDSK isn't really applicable to SSDs.
http://forums.anandtech.com/showthread.php?t=2070015
Maybe my Win7 has become corrupt? I left my computer on last night. This morning all that showed was the desktop background. No start button, tool bar or anything else showed. The mouse still worked (could move it around the screen) but right clicking did not. I have not installed any new software or hardware, nor have I visited sites I haven't normally visited or opened strange email.
What's going on?! Help!
Old 09-23-2012, 07:50 AM   #6
Have got the latest bios? Try SSDlife Free to check your ssd....
SSD life - tool for solid state drives health and endurance monitoring
Old 09-23-2012, 08:48 AM   #7
mindx2
mindx2's Avatar
SSDlife finds no errors and my firmware is up to date according to Crucial's Firmware Update program.
My computer keeps blue screening and rebooting. When rebooting it doesn't see the SSD. I have to physically turn off the computer and restart it several times for it to "see" the SSD again. However, within the hour it will reboot and I go through the same thing.
This is a similar problem like http://forums.crucial.com/t5/Solid-S...ng/td-p/107678
Old 09-23-2012, 08:56 AM   #8
How about the bios of the motherboard?
Old 09-23-2012, 09:25 AM   #9
mindx2
mindx2's Avatar
I did have to update the BIOS. We'll see if that helps
Old 09-23-2012, 09:57 AM   #10
In addition to the other suggestions:
Possibly a bad SATA cable. Try that first.
Possibly a bad SATA port. Try that second.
If those don;t solve the problem, it's possibly a bad SSD. If you have a good image of the C partition, restore it to another HDD and put the HDD on the same cable and port. If the problem is solved, the SSD is bad.
Old 09-23-2012, 10:00 AM   #11
mindx2
mindx2's Avatar
I didn't even think about the SATA cable I'll try that if the problem persists.
Old 09-23-2012, 11:09 AM   #12
I may be wrong, but your problem reads like windows is corrupted.
What about windows repair disk it may help. Put windows os disk in
and run the windows repair ..... Anywho hope ya find the answer
my friend.
Old 09-23-2012, 11:16 AM   #13
BSOD's a lot of times are caused by a memory issue. I would check your memory sticks out for seating and timing/voltages. After that, I would suspect a corrupt Windows or other software messing up writing to your memory. I would use System Restore to go back when you didn't have this issue. If all else fails I would do a complete re-install of Windows. If the problem still persists after a Windows re-install then it is most likely a hardware issue. Good luck!
Corsair 760T Arctic White / ASUS ROG RAMPAGE VI APEX / Intel i9-7900X / ASUS ROG-STRIX-GTX1080-O8G-11GBPS / Corsair Dominator Platinum 32GB (4 x 8GB) DDR4 DRAM 2666MHz C15 / SeaSonic Prime 750W Titanium / ASUS ROG SWIFT PG348Q / Intel Optane SSD 900P 480GB / Samsung 960 EVO M.2 500GB / Samsung 850 Pro SATA 1TB / Ducky Shine 3 YOTS / Razer DeathAdder Elite / ASUS OC Panel / ASUS Essence STX / Audioengine HDP6, N22, S8 / AKG K712 PRO
Old 09-23-2012, 12:32 PM   #14
mindx2
mindx2's Avatar
That's guys. I've changed the SATA cable so I hope that is it. If not I'll try a System Restore. Thanks again
Old 09-23-2012, 12:42 PM   #15
You're welcome, I hope this resolves your problem...
