Old 11-07-2012, 03:41 PM   #1
steven
C programming using Processes under Windows
I am not sure i am in the correct section, but if that be the case i ask a moderator to move my thread.
Okay, so anyone knows where i can find some learning material (prefferably interactive, as i am more of a practical guy) to get me going with the processes stuff. (PIPE FIFO and so on)
Just bought
. I'm so proud of it so far.
Intel Core i7-960 3.2-3.4Ghz Processor
Innovation Cooling IC Diamond 24 Carat for CPU + GPU
8GB 1333Mhz RAM (2x 4GB Configuration)
500GB 7200rpm Seagate Hard Disk
nVidia Geforce GTX560M 1.5GB GDDR5
Old 07-17-2013, 02:46 PM   #2
TingKermite
TingKermite's Avatar
Re: C programming using Processes under Windows
Can you be more specific?
Get you going how? PIPE is an output stream, and doesn't "necessarily" have much to do with C programming (other than the mechanism for which text is put back to the console). FIFO is just a "type" of of a type of data structure (queue).
Sounds like you are interested in C programming and processes, but if you can be more specific as to what you might want to do, I may be able to point you in a helpful direction.
