Old 07-15-2013, 06:00 PM   #1
ISP Upgrade -- 112 mbps!!!
My ISP, Cablevision's Optonline service, which serves much of the New York/Connecticut/New Jersey area, has just introduced new upgraded speed tiers. The base tier was upgraded from 15 mbps down/2 mbps up to 15/5, with two extra cost additional tiers, 50/25 and 101/35.
As a long-time ("legacy") customer of one of their previous extra-cost tiers, which provided 30/5 for $14.95 per month above the base rate, I was eligible for an upgrade to 101/35 at that same cost! Today I went to their local facility and exchanged the DOCSIS 2 cable modem they had provided many years ago for a DOCSIS 3 cable modem, and voila:
http://www.speedtest.net/result/2838746096.png
During other runs, I've seen as much as 118 mbps, although sometimes as low (!) as 90 mbps. Uploads have varied from around the 18 mbps shown up to a little more than the advertised 35 mbps.
And just as incredibly, I'm getting close to 80 mbps downloads via wifi, from a laptop on the first floor of my house that is wirelessly connected to an access point on the second floor:
http://www.speedtest.net/result/2838787318.png
All of this is via a SonicWall TZ205 hardware firewall/router. The wireless access point is an EnGenius EAP350.
Awesome!!!!
Best regards,
Old 07-15-2013, 06:42 PM   #2
nice !!!
Old 07-16-2013, 09:09 PM   #3
Re: ISP Upgrade -- 112 mbps!!!
Awesome indeed!!
Dang, FIOS pulled out of most of NH, so I doubt Comcast has much incentive for boosting speeds anymore (though we did get a one time boost to accommodate Netflix's SuperHD (or whatever it's called).
Old 07-19-2013, 12:46 AM   #4
Alex
