Old 10-19-2013, 11:54 AM   #1
Install W-8.1 bypassing Microsoft account
Here's how to keep your PC off the CLOUD, while installing W-8 or W-8-1.
Windows 8.1 Preview How to install without Microsoft account (skip Microsoft account) | Infobyte Blog
This one I just completed, now my PC is a Local Account free of the cloud...
How to Switch from a Microsoft Account to a Local Account in Windows 8 and 8.1 .... Local Account - Switch to in Windows 8
Old 10-19-2013, 12:55 PM   #2
Re: Install W-8.1 bypassing Microsoft account
Very nice Skully this should help a lot for people who do not want a Windows Live account!
Old 10-19-2013, 01:14 PM   #3
JimTram
Seabees, USN (Retired)
JimTram's Avatar
Is the MS account separate from the password required to gain entry to the computer?
I can see some problems here!
CyberPower CP1350PFCLCD
Sennheiser HD280 Pro
Win10 Pro 1703
Old 10-19-2013, 01:14 PM   #4
Thanks... I hope it helps, and makes 8.1 more attractive to those who
want full control of their PC.
Old 10-19-2013, 01:19 PM   #5
JimTram
JimTram's Avatar
Interesting:
500,000 Americans' IDs, bank data stolen and sold on Internet, indictment says - Investigations
Win10 Pro 1703
Old 10-19-2013, 01:20 PM   #6
GWillakers
Thanks for the Heads up Skully.
Old 10-19-2013, 01:31 PM   #7
Originally Posted by JimTram View Post
Is the to gain entry to the computer separate from the password required to gain entry to the computer?
A local account needs no password to log on to a PC, only if you want to use one. I just disconnect from my MS account, and closed out my MS account.
Using this method....
Local Account - Switch to in Windows 8 and this... Microsoft Account - Close
Old 10-19-2013, 01:32 PM   #8
Your welcome my friend...
Old 10-19-2013, 01:54 PM   #9
JimTram
JimTram's Avatar
Thanks Skully. If you use EFS like I do, a password to gain entry to the computer is a must. The encrypted file system uses the login password for the encryption scheme. Also, to keep Outlook encrypted, a password must be used. A lot of people use their login, as Outlook will then automatically use it.
So what I read is, the "traditional" login is available for use if desired. MS account is not mandatory.
Which leads me to, if you did use the MS account, is the account password, the password you use to login in to the computer?
All in all, MS is getting closer to the Apple scheme. I trust Apple, not MS, only because of the sheer numbers of users.
Win10 Pro 1703
Old 10-19-2013, 02:35 PM   #10
Thanks Skully. If you use EFS like I do, a password to gain entry to the computer is a must. The encrypted file system uses the login password for the Which leads me to, if you did use the MS account, is the account password, the password you use to login in to the computer?scheme. Also, to keep Outlook encrypted, a password must be used. A lot of people use their login, as Outlook will then automatically use it.
"Which leads me to, if you did use the MS account, is the account password, the password you use to login in to the computer?" Yes...
You may need to look into the password thing/encryption... You maybe
able to use a local password for encryption/Outlook. In other words If
you can do it now without MS and the cloud. I believe you can with W-8.1 also...
Old 10-19-2013, 03:13 PM   #11
JimTram
JimTram's Avatar
Thanks Skully. Hard questions, I'm sorry. However, your chemo brain needs a workout.
Win 8.1 Pro has EFS, so I suspect all is the same.
Thanks again.
Win10 Pro 1703
Old 10-19-2013, 04:11 PM   #12
Thanks again.
You're welcome...
Yea that gave me chemo brain a good workout...
Old 10-20-2013, 11:47 AM   #13
Hey guys, which version of Windows 8.1 is the best to get?
I would like a hard copy and 64bit.
I'll be sure to follow Skully's guide to not installing the Cloud/Live part.
Not sure when I am getting it but maybe soon.
Thanks,
Old 10-20-2013, 12:43 PM   #14
Griff
Griff's Avatar
Thanks,
I have the Pro version, works great for me...
Obsidian 550 Corsair Case
Asus Motherboard P8Z77-V PRO
Intel i7-3770K Unlocked
Arctic Cooling Freezer 13
Samsung 840 EVO SSD For O/S
LG BlueRay Burner
Seagate1TB SATA for Photos
Built in Card Read
Win10 Pro
Old 10-20-2013, 01:19 PM   #15
Is yours a retail version on DVD? That is what I will try to get. Looks like it costs $199.
