Old 11-10-2013, 07:58 AM   #1
flex22
flex22's Avatar
windows 8.1 slow
hi guy's just wondering if it's my computer or win 8.1 the same web pages I always went to are now opening really slow. and even typing I get one letter at a time. and I don't typing all that good really a problem. any one else experiencing this.
Motherboard
ASUS P4P800 Deluxe 1016 Bios
Processor
2.8 E Prescott
Memory
2x512 xms corsair PC3200
samsung 80GB wd120JB l o/s XP PRO l X-Dreamer-case
PC2 P4 1.8 o/s Win2K l 2x512 PC2700 l
Old 11-10-2013, 08:06 AM   #2
Re: windows 8.1 slow
Sounds like a connection or server problem to me, not your OS.
Old 11-10-2013, 08:53 AM   #3
It isn't that way on my laptop running W 8.1, everything seems super quick? What Browser are you using, if its Chrome there is a problem, IE 11 is fast.
Old 11-10-2013, 10:11 AM   #4
flex22
flex22's Avatar
I did a speed test and called AT&T i'M GETTING THE SPEEDING i'M SUPPOSE TO GET (excuse the caps) didn't see they were on. even as I type this one letter at a time comes up.and using chrome
Motherboard
Processor
2.8 E Prescott
Memory
Old 11-10-2013, 10:35 AM   #5
Try IE 11 and see if it makes a difference, Chrome is definitely slower on my laptop than IE 11!
Old 11-10-2013, 10:44 AM   #6
Didn't even know there was an IE 11 for Windows 7. I've been using IE10.
Old 11-10-2013, 10:47 AM   #7
flex22
flex22's Avatar
I launch IE11 12.5 sec to open and on this site I got a message at the top shockwave not responing
Motherboard
Processor
2.8 E Prescott
Memory
Old 11-10-2013, 10:55 AM   #8
Just installed IE11 on this rig, IE11 came with W8.1 on my new laptop!
Old 11-10-2013, 10:56 AM   #9
What type of speeds are you getting..go here and try...
Speakeasy Speed Test
Old 11-10-2013, 11:06 AM   #10
flex22
flex22's Avatar
from chicago down 19.36 up 1.47
new york down 21.65 up 1.47
Motherboard
Processor
2.8 E Prescott
Memory
Old 11-10-2013, 11:27 AM   #11
Those are good speeds, have you got of W8 updates?
Old 11-10-2013, 01:13 PM   #12
I installed IE11 for Windows 7 and all went well. It kept all my plugin settings and I didn't have to change anything. It messed up my desktop gadgets though and the right-click search with mouse didn't do anything.
I used system restore and went back to IE10. Usually if this was a legit upgrade you would see it advertised or in the Windows update window. I don't think it is ready for primetime in Windows 7.
Is IE11 the default browser for Windows 8.1?
Old 11-10-2013, 02:14 PM   #13
Griff
Griff's Avatar
I just checked and it appears IE 11 is used in Win 8.1...
Obsidian 550 Corsair Case
Asus Motherboard P8Z77-V PRO
Intel i7-3770K Unlocked
Arctic Cooling Freezer 13
Samsung 840 EVO SSD For O/S
LG BlueRay Burner
Seagate1TB SATA for Photos
Built in Card Read
Win10 Pro
Old 11-10-2013, 03:19 PM   #14
Yes it is and it did the same to my desktop gadgets also.
Old 11-10-2013, 03:50 PM   #15
Going TDY for a while so I won't be able to install Win8.1 until I get back. FYI, Windows 9 might appear sometime next year and it will be bringing Aero back to the desktop. Also, after 9 comes 10 and it is suppose to all MS Cloud based. Another nail in the desktop coffin.
