Old 12-29-2013, 08:40 AM   #1
Is W8.1 Automatically running Trim?
Can you guys who have W 8.1 check and see if your automatically running optimize my ssd when its set to run daily? I have mine set to run daily (thank you Skully) but when I check it says hasn't been done in days (sometimes) so I have to run it manually?
Old 12-29-2013, 10:12 AM   #2
Re: Is W8.1 Automatically running Trim?
Hey Ken, I just checked mine and it reads optimized 12-28-2013 yesterday.
I've never found my RAID-O at the end of a day not optimized. My RAID-O
has always been TRIM'ed daily with W-8.1...
Old 12-29-2013, 03:58 PM   #3
Griff
Griff's Avatar
Mine is not optimizing daily either, I have to do it manually too. What is the trick to have it done daily?
Obsidian 550 Corsair Case
Asus Motherboard P8Z77-V PRO
Intel i7-3770K Unlocked
Arctic Cooling Freezer 13
Samsung 840 EVO SSD For O/S
LG BlueRay Burner
Seagate1TB SATA for Photos
Built in Card Read
Win10 Pro
Old 12-29-2013, 04:32 PM   #4
Thanks Jerry I would like to know that one too???????????????
Old 12-29-2013, 04:44 PM   #5
Griff
Griff's Avatar
I had a look here and made a change or two. Will see what happens tomorrow when I check it. Will let you know.
Windows 8.1 SSD Settings, Etc. » TweakHound
LG BlueRay Burner
Built in Card Read
Win10 Pro
Old 12-29-2013, 04:58 PM   #6
Thanks Jerry!
Old 12-29-2013, 07:05 PM   #7
Hey guys, I discussed this in another thread so you may have already read it (link at Tweakhound, WinSAT).
I already advised you to run WinSAT which determines you have an SSD and makes appropriate changes. It may run automatically for the first time after you install win8.1 but if you went from win8 to win8.1 you need to run it.
Old 12-29-2013, 07:58 PM   #8
I installed 8.1 and I still have this problem, it wasn't a upgrade.
Old 12-29-2013, 10:20 PM   #9
Griff
Griff's Avatar
I also installed 8.1 did not upgrade.
LG BlueRay Burner
Built in Card Read
Win10 Pro
Old 12-30-2013, 05:39 AM   #10
Pentium4
Pentium4's Avatar
Mine defaults to optimize on a weekly basis, but it never does I checked it this morning, and it's showing it hasn't been done in 28 days, but I always
do mine manually after my regular format, and reinstall to make sure both partitions are as good as they can be
INTEL INSIDE
* Gigabyte GA-Z97X-G7 * Intel i7 4790K * G.Skill 2400MHz TridentX 16Gb DDR3 (10-12-12-31-1T) *
* Samsung U28D590 28" 4K Monitor * Palit GTX780 VGA (967/6010) * Samsung 850PRO 1TB SSD *
* LG CH12LS28 Blu-ray Optical Drive * CM Xornet II Gaming Mouse * Onboard 5.1 Surround Audio *
* Logitech K200 Keyboard * Tt VersaII Mid-Tower Case * SeaSonic XP1000W PSU (100% Modular) *
Old 12-30-2013, 08:00 AM   #11
Thanks for the input, the scheduler doesn't seem to be working? I unchecked all drives to be optimized and just checked C drive, I'll see if that makes a difference.
Old 12-30-2013, 02:08 PM   #12
Well so far nothing, says its been 3 days since it ran....
Old 12-30-2013, 10:53 PM   #13
Griff
Griff's Avatar
Mine has not run in the last 30hrs since I changed a few settings.
LG BlueRay Burner
Built in Card Read
Win10 Pro
Old 08-06-2014, 10:23 PM   #14
Anybody ever check disk optimization dates on your SSD and run it manually if it is past due?
Old 08-06-2014, 10:58 PM   #15
I just check mine once in awhile, and most cases its right up to snuff...
