Old 03-14-2014, 11:41 AM   #1
creating a text list of all the files that are in a folder
I wanted to get a text list of all the files in a particular folder.
I tried command prompt navigating to the directory, and then using DIR > MyList.txt and it creates a text file called MyList but inside are a lot of additional info such as some byte count etc instead of only purely the file names.
Any suggestions what i should do to get only the file names alone as a list into a .txt
Old 03-14-2014, 07:56 PM   #2
Re: creating a text list of all the files that are in a folder
Just use the /b switch on DIR, should work.
Old 03-15-2014, 08:36 AM   #3
Brings back old memories.
Old 03-17-2014, 10:34 AM   #4
