Old 09-16-2014, 10:40 PM   #1
Hibernation is fast, the resume is the problem, it takes painfully long
My system used to hibernate and resume very instantaneously.
Now suddenly noticed this problem and its happening regularly for the past 2 months in that the hibernate still always performs as before. But the resume bar which says "windows is resuming" or something like that takes very long. 3-5 mins at times.
Any suggestions as to what might need to be done. I have a lot of spare OS drives sitting around now, but i just wanted to try other options before changing hardware.
Thanks in advance.
Old 09-17-2014, 12:49 AM   #2
JimTram
Seabees, USN (Retired)
JimTram's Avatar
Re: Hibernation is fast, the resume is the problem, it takes painfully long
Delete the hiber file and reinstall. MS has fixit program for this.
CyberPower CP1350PFCLCD
Sennheiser HD280 Pro
Win10 Pro 1703
Old 09-18-2014, 12:13 AM   #3
I tried searching for hiberfil.sys but even with show hidden files toggled i cannot seem to find it.
How do i go about this ?
And if i get thru the delete part, how do i do a reinstall ? What is to be reinstalled ?
Old 09-18-2014, 12:55 AM   #4
JimTram
JimTram's Avatar
Ms website has both fixit tools to remove and install the file. In power settings you can confirm the presence of hibernation. Strange the file does not show in the root directory of os drive.
Win10 Pro 1703
Old 09-18-2014, 05:34 PM   #5
JimTram
JimTram's Avatar
How to disable and re-enable hibernation on a computer that is running Windows
Win10 Pro 1703
Old 09-19-2014, 11:56 AM   #6
Power settings correctly shows hibernation as enabled. Tried disabling and enabling. Everything does what its supposed to except. I cant seem to locate the hiberfil.sys even with a global search when hidden files are enabled to show.
Old 09-19-2014, 12:24 PM   #7
JimTram
JimTram's Avatar
It should be in the root folder along with the page file. Sounds like to me it's being deleted routinely!
Try the tools, they may help.
Read this:
How to fix hibernation file issues in Windows 7 | Interface Technical Training
Win10 Pro 1703
Old 09-19-2014, 10:46 PM   #8
Actually when you do a global search with hidden files enabled its supposed to turn up in the results correct ?
Old 09-20-2014, 01:07 PM   #9
JimTram
JimTram's Avatar
Only if you have indexing locations setup correctly.
Win10 Pro 1703
Old 09-23-2014, 07:00 AM   #10
For the desktop I have stopped using hibernation or sleep, computer boots very fast.
Old 10-08-2014, 09:53 PM   #11
No matter what ive tried. Its still slow. Even if i deactivate & reactivate hibernation. The first time hibernation/restore is fast. But after 2 times of hibernating. The restores alone get dead slow. Entering into hibernate however is still fast as always.
