Old 02-05-2015, 12:08 PM   #1
nkumar2171
Thumbs up How to Create System Performance Report on Windows 8, 8.1
The performance of Windows 8 depends on a number of factors. The System Performance Report is one of the features of Performance Monitor tool. It is a report that produces the details of your system and based on the information provided you can decide on the possible reasons of the system issues. A System Performance Report provides you the position of local hardware resources; you can find out how your system performs over time, etc. Here in this article we will show you how to Create and view System Performance Report. Follow the easy steps and get the reasons behind your systems issues and thus improve your systems performance.
How to Generate System Performance Report on Windows 8, 8.1
  • Press Windows + R keys jointly on the keyboard.
  • A Run dialog box will appear on the screen.
  • Type perfmon on the text field provided.
  • Click Ok.
  • perform in the run box
  • A User Account Control will prompt for your permission.
  • Click Yes to proceed further.
  • A Performance Monitor window appears on the screen.
  1. Now navigate the following path
  2. Data Collector Sets\System\System Performance
  3. Right click on System Performance
  4. Select Start.
Now it will collect the data.
How to View System Performance Report
  • Click the Reports option on the left pane of the window.
  • Then click System.
  • Now click System Performance.
  • Click on the report and view the details.
  • system performance report.
You can get more tips on
Howtoconnect - Windows 10 | 8 How-to, Tips, Tutorial, Guide
Old 02-05-2015, 05:37 PM   #2
Re: How to Create System Performance Report on Windows 8, 8.1
This is neat info.
