Old 02-21-2015, 12:31 AM   #1
SRTDodge05
SRTDodge05's Avatar
Asus RT-N66R Wan Speed
I've had an Asus RT-N66R as my main router for about 2 years now. I also have the same router on the second floor setup as a AP only. I've been playing with different firmware's lately for the best performance. My Wan port is rated at 1000mb. I'm using a Motorola SB6141 on Comcast. For whatever reason neither one of these routers want ports will run at 1000mb as they are rated. I tried cat5e and cat6 cables at 6ft long and no change. If I plug my modem into my pc or into a network switch I get 1000mb. On the router if I have more modem or a network switch plugged into the wan port 100mb is max. I've installed the same combo Motorola SB6141 and the Asus RT-N66R at 3 different locations and all of them have the same issue.
What would be causing this?
Old 02-21-2015, 09:41 AM   #2
Re: Asus RT-N66R Wan Speed
Here's an active thread on your problem. One thing I read was to have your ISP hard set your speed to 1Gbit. You cannot have hard set on one end and auto on the other.
http://www.linksysinfo.org/index.php...to-100m.70260/
Old 02-21-2015, 11:02 AM   #3
SRTDodge05
SRTDodge05's Avatar
Its just weird that when the modem is plugged into my computer it will connect at 1000mb. Also when I plug the modem into a gigabit switch it will connect at 1000mb. Guess buying the router for 1000mb Wan connection was a waste of money.
Old 02-21-2015, 11:06 PM   #4
SRTDodge05
SRTDodge05's Avatar
Like I said I have two of the RT-N66R routers. My main router will not work on gigabit WAN. I reset it and tried a few firmware's with no luck. I take my second router and reset it from AP only to normal mode. This unit WAN will run at gigabit. Both units are Ver B1 but one I bought like 5 months after the first one.
Old 02-22-2015, 09:47 AM   #5
Are you substituting them so they are both tried under identical cables? If so, then it is the MODEM. Put in an RMA to ASUS.
Old 02-22-2015, 10:10 AM   #6
SRTDodge05
SRTDodge05's Avatar
First I've been using the WAN port will not run at 1000mb when plugged into the modem or my gigabit switch. I grabbed my second router and that connected at 1000mb right away when connected to my modem and switch. I used all the same cables as before. Not sure how long the warranty is for asus.
Old 02-22-2015, 10:32 AM   #7
I misspoke, I meant it is your ASUS RT-N66R router, not the MODEM.
ASUS usually has 3yr warranty's. You go online register the product and then submit a ticket. I have never had to do this but this how it works if I remember. My guess is you would get a new router back.
Old 02-27-2015, 06:14 PM   #8
SRTDodge05
SRTDodge05's Avatar
I got a RMA for my router but not sure if I'll do it. I have to pay to have shipped then wait a week or so for a replacement (hopefully). I might just say screw it and just go buy another one.
