Old 05-21-2015, 08:54 PM   #1
Windows Event Viewer
Hey clan,
I just performed a fresh install. I outlined exactly what and the order of what I installed as far as necessary drivers. Pretty basic. I then let Windows auto update.
I have been having a USB issue with something trying to connect and disconnect. I can not see it because I am doing something when it happens and I lose keyboard and mouse control. The switch only lasts a few seconds and it is gone. I have been looking at the Windows Even Viewer to see what is going on but I still can't make much of it.
I try to click 'Event Log Online Help' but the URL is not good (thanks Microcrap). I seem to always have an event log full of warnings and errors and was wondering what other peoples event logs look like. For example, one says abnormal shutdown. I have not shut down abnormally yet.
Anyway, to view go to Control Panel/Administrative Tools/Event Viewer.
Old 05-22-2015, 01:36 AM   #2
Re: Windows Event Viewer
Heres mine... its about like yours a mess....
Old 05-22-2015, 07:21 AM   #3
Thanks Skully, I think things like using ASUS Boot Setting might screw with the shutdown process I don't know but my PC runs good even with events from time to time. There is always a lot going on with Windows, just look at the amount of services and processes running at one time.
I reinstalled my printer driver last night and I have not seen the USB issue return yet. It is a very minor bug and I know it will go away eventually. The Deluxe should be a very solid mobo, I know the X99-A was and it is just a derivative of the Deluxe. I am using the Deluxe in the same capacity as the X99-A, I just wanted it for the white bling.
Old 05-22-2015, 10:22 AM   #4
Yea my windows/system all run well even with the events, I tend to agree with you, alot going on in window os. glad to hear you fixed your USB issue...
Old 05-22-2015, 10:54 AM   #5
JimTram
Seabees, USN (Retired)
JimTram's Avatar
Here's mine. If you want to really become a nervous wreck - pay attention to Event Viewer.
If the rig works, and your not getting too many Critical errors - enjoy it!
Best way to get answers on the events is to Google them. Solved a bunch I had when I first started up. Discovered that many errors are in fact benign, and as long as WU works, and the computer is stable, all's good!
Example: I always get one audit failure. Traced it down to a known issue with the Realtek drivers. Benign. Best sound I ever had.
CyberPower CP1350PFCLCD
Sennheiser HD280 Pro
Win10 Pro 1703
Old 05-22-2015, 01:23 PM   #6
JimTram
JimTram's Avatar
Got rid of the RealTek Driver - no audit failures.
Win10 Pro 1703
Old 05-22-2015, 07:26 PM   #7
You should have warned me earlier about Event Viewer lol.
I only looked in it because I had an issue. I reinstalled my printer driver last night and have not seen the USB issue yet. Something was trying to install some printer device driver. I had 3 printers in Devices and Printers. I deleted the two MS ones.
I think Realtek has pretty good drivers. You may want to go to Realtek's site an look for the latest. 90% of mobo's use a Realtek audio chip. If you are using onboard sound I would think you need the Realtek audio drivers to make it work to its fullest.
Old 05-22-2015, 09:45 PM   #8
JimTram
JimTram's Avatar
The drivers work fine. The audit failure annoyed me. With iTunes the MS drivers sound as good.
Win10 Pro 1703
Old 05-23-2015, 06:46 PM   #9
JimTram
JimTram's Avatar
Well it took me overnight, but I found the issue with the single Audit Failure I was getting.
After trying Realtek drivers from both ASUS and Realtek - I stumbled on a RealTek driver at Intel's site. Installed it and no more Audit Failures.
Got to stop looking at Event Viewer.
Win10 Pro 1703
Old 05-30-2015, 03:48 PM   #10
Yea stay out of there...
Old 05-30-2015, 05:57 PM   #11
JimTram
JimTram's Avatar
I'm addicted to it as it is just as much of a challenge as OC.
Win10 Pro 1703
Old 05-30-2015, 09:47 PM   #12
You can find help here...Windows Event Viewer Anonymous...
Old 05-31-2015, 11:21 AM   #13
JimTram
JimTram's Avatar
Talking Re: Windows Event Viewer
I'm Done
Win10 Pro 1703
Old 05-31-2015, 11:25 AM   #14
I'm Done
Congrats.....
Old 05-31-2015, 03:18 PM   #15
Yea nice clean up Jim...
