Old 09-01-2015, 06:32 PM   #1
switch_abx
HIGH ALERT! Windows 7, 8, and 10: Now all collecting user data for Microsoft
Windows 7, 8, and 10: Now all collecting user data for Microsoft | InfoWorld
This is what the article recommends:
The easiest way to prevent the Diagnostic and Telemetry Tracking service from sending any data is to not install the mandatory update at all and to remove it -- and the optional fixes -- from Windows Update so that they don’t get installed by mistake later. If the updates have already been installed, they can be uninstalled via Control Panel by looking up the KB identifier for updates. They can also be removed by running the wusa /uninstall command from an elevated command prompt.
Old 09-01-2015, 06:57 PM   #2
Re: HIGH ALERT! Windows 7, 8, and 10: Now all collecting user data for Microsoft
It seems that MS has decided that the real money is in being an information company, not a software company.
Old 09-01-2015, 07:23 PM   #3
switch_abx
Yes, indeed. But it's done covertly in a creepy way. All users of these systems just aren't aware that they are becoming subject to a collective spying operation. NSA is looking over the shoulders of MS, to get their part of the information stream flowing to MS Servers.
My guess: industry will be forced to drop MS as a serious software developer.
This is insane.
Old 09-01-2015, 10:43 PM   #4
switch_abx
Here a little Howto to deinstall in Windows 7 the relevant KBs (the Microsoft Trojan Horses) mentioned in the publication of InfoWorld:
Go to Control Panel > System and Security > Windows Update > View installed updates.
Locate KB 3022345 (May 15, 2015). Right click on this KB and click on deinstall. Wait until it has been deinstalled.
Subsequently do the same for:
KB 3080149
KB 3075249
KB 3068708
Restart the computer.
After the reboot, go to Control Panel > System and Security > Windows Update > Check for updates.
You will see that the following KBs appear ready to be downloaded again.
KB 3068708
KB 3075249
KB 3080149.
Right click each KB and select Hide update. This will avoid that these KB updates will be installed now again or in the future.
Old 10-20-2015, 08:58 AM   #5
bobmitch
bobmitch's Avatar
Yo can fix this a few ways:
Fix Windows 10 privacy
OR the short way:
OO ShutUp10: download free antispy tool for Windows 10
Old 10-20-2015, 09:08 AM   #6
Thanks for the links, good info!
Old 10-20-2015, 02:45 PM   #7
Griff
Griff's Avatar
I have been using the OO Shutup10 ever since I posted a link to it way back in the thread. Works good.
Obsidian 550 Corsair Case
Asus Motherboard P8Z77-V PRO
Intel i7-3770K Unlocked
Arctic Cooling Freezer 13
Samsung 840 EVO SSD For O/S
LG BlueRay Burner
Seagate1TB SATA for Photos
Built in Card Read
Win10 Pro
Old 10-20-2015, 03:51 PM   #8
Thanks Jerry sounds like a winner!
Old 10-21-2015, 06:27 AM   #9
OO ShutUp10 seems like a quality program. So much in there I just went with applying recommended settings. I wonder if something like this exists for Office2016? I should install Office 2016 and then run ShutUp10?
Thanks Griff and bobmitch.
Old 10-21-2015, 08:28 AM   #10
Griff
Griff's Avatar
It has been working well for me since I installed it.
LG BlueRay Burner
Built in Card Read
Win10 Pro
