Old 10-17-2015, 06:28 PM   #1
kbk_75
F1 Fanatic!
kbk_75's Avatar
Any way to force DNS server?
I have a 4G wireless device that provides my home with Internet connectivity. To be clear this is a router that picks up my ISP's 4G signal, it has no wifi capability of its own. For that I have a cable running from the 4G router to my wifi router, from where my PC, home theatre, consoles etc get a wired connection and all my wireless devices get their wifi.
My problem is that my ISP's router has no tab to choose custom DNS servers. I guess they want to force me to use theirs. The trouble is their DNS servers go down for several minutes, several times each day, which gets very tiresome. I have set my wifi router and each of my devices individually to use Google's DNS servers but, since my final access point to the net is the 4G router, it seems everything just goes via my ISP's shitty DNS servers anyway.
Is there any way for me to truly use whichever DNS server I want and not be forced to suffer my ISP's shitty DNS servers? I have PC and Mac devices FYI.
Thanks.
Edit: I cannot change the 4G router to another device that allows custom DNS settings because my ISP has my SIM card locked to the router they provide. Besides, I'm not aware of any other easily available 4G outdoor receivers like the one I have.
Current Rig:
2.4GHz E6600 Core2 Duo @ 3.5GHz | Thermalright Ultra 120 Extreme + 120mm Scythe | Asus Striker Extreme | 4x2GB Mushkin DDR2-800 | 2xPNY Factory OC'd Geforce 8800GTX SLI 621 Core, 2000 Mem | 3xSamsung Spinrite 500GB SATA RAID 0 | 1 Seagate 7200.11 1.5TB | 6X LG Blu-ray Burner / HD-DVD Reader | 18X Asus Lightscribe DVD DL Burner | Sound Blaster Fatal1ty Extreme Gamer | 24" Dell 2407WFP-HC | Razer Lycosa Mirror Edition Keyboard | Logitech MX Revolution Mouse | Logitech Quickcam Orbit | Coolermaster CM Stacker 830 + 1200W Thermaltake Toughpower PSU | 4xScythe 120mm + 2 Coolermaster 120mm LED case fans | Vista Ultimate 64bit
Other Rig:
2.4C SL6Z3 M0 P4 @ 3.2 | Thermalright SLK-900U + 92mm Vantec Tornado | Asus P4C800-E Deluxe BIOS 1023 | 2x512MB OCZ PC4200 EL 3-4-4-8-4 1:1 | 512MB Gainward 7800GS+ @ 600/1460 | 2xWD 73GB Raptor ICH5R SATA RAID 0 | 1xSeagate 7200.7 160GB onboard Promise SATA RAID | 1xHitachi 7K500 500GB onboard Promise SATA RAID | 16X Asus DVD-ROM | 8X Plextor 708A DVD/RW | Sound Blaster Audigy 2 | 20.1" Viewsonic VP-201b | Logitech MX 3000 Keyboard + Mouse | Logitech Quickcam Orbit | Thermaltake Xaser III V2000A + 850W Coolermaster PSU
Old 02-28-2016, 09:12 PM   #2
Falklan
Sing your death song!
Falklan's Avatar
Re: Any way to force DNS server?
If you haven't found the solution to this problem yet...
You need to go into your NIC properties and input specific DNS addresses...
However, this will only apply to the device/computer you are using and NOT the 4G modem...
Post the make/model of your 4G modem and I will research it.
MSI Z87-G45 - Intel Core i5 4670K (4.4GHz) - Corsair H100i - Gskill RipjawsX 16GB (2133MHz)
MSI GTX 1060 6B Camo Squad - MSI GTX 650Ti Boost (PhysX)
CM Silent Pro M2 720W - HAF 922
(2) Samsung 850 Pro 128GB (RAID0-OS Only) - Crucial 240GB (game cache)
(2) WD Black 1TB (storage/backup)
Samsung 830 128GB (scratch/cache)
Pioneer BD+R - Samsung DVD+R
Samsung 32" HDTV - Dell 21.5" LCD
KB: NPET P010 - Mouse: MSI Interceptor DS B1
Windows 10 Pro x64
Behringer Q1002USB - BM-800 Condenser Mic/Boom
