Old 11-12-2015, 05:15 PM   #1
Windows 10 Fall Update is Here!
Well I got my laptop updated, my two other rigs not yet, took about 15 minutes, almost has long has going from W8.1 to W10...only problem I had was Windows live mail somehow lost a dll file and wouldn't work, but I just did a repair from programs and features and it fixed it...so far so good! You'll see this when your done...verison 1511 build 10586.0...
Old 11-12-2015, 08:28 PM   #2
Re: Windows 10 Fall Update is Here!
Hey FVB, I got the upgrade.
I DL the installer tool just like I did for my original installation. It put the ISO on a USB thumbdrive so I now have the full blown Windows 10 Pro x64 installation with Threshhold 2. I backed up the USB drive to my internal storage and ran the upgrade process from there. Desktop and programs are in exact same condition as before. Did not have to worry about any keys or activation either.
Old 11-12-2015, 08:32 PM   #3
Good deal I need to put it on a thumb drive also...
Old 11-13-2015, 07:17 AM   #4
Dose it say on your system using the that tool, version 1511 build 10586.0?
Old 11-13-2015, 10:02 AM   #5
Well I did a manual upgrade like Sandog and it worked just like the upgrade did on my laptop....here's what it looks like after your done...
Old 11-13-2015, 11:43 AM   #6
Here's a little tip for making a bootable thumbdrive for you W10 install, use GPT instead of MBR...here's the reason....I had to redo mine because I used MBR and I don't want any problems.
How to create a Windows 10 USB installation media with UEFI support | Windows Central
Old 11-13-2015, 03:34 PM   #7
I used the MS Win10 installation tool to put the install on USB thumbdrive using UEFI method. With the modern mobo's we have you want to use UEFI. There are menus in the BIOS for UEFI thumbdrives whatever it is. I think UEFI BIOS can now recognized NFTS or 64bit maybe on thumbdrives. Also, UEFI BIOS can see into your system drives. Whatever it is it works.
Old 11-14-2015, 09:15 AM   #8
Just got my wifes rig updated from Windows update this morning, took a couple of days for her to get it!
Old 11-14-2015, 11:03 AM   #9
Griff
Griff's Avatar
I did the update this morning. Goes rather quick. I used the usb thumb drive method.
Obsidian 550 Corsair Case
Asus Motherboard P8Z77-V PRO
Intel i7-3770K Unlocked
Arctic Cooling Freezer 13
Samsung 840 EVO SSD For O/S
LG BlueRay Burner
Seagate1TB SATA for Photos
Built in Card Read
Win10 Pro
Old 11-14-2015, 11:29 AM   #10
Good deal Jerry welcome to the fall update club...lol
Old 11-14-2015, 03:04 PM   #11
Yep the same here, USB thumb drive method... Alls well...
Old 12-04-2015, 03:03 AM   #12
So, what's the lowdown guys? Any improvements with the update now that it been out a few weeks? I said I'd wait till Threshold 2 before I decided to upgrade (or, more likely, do a clean install). Any thoughts, suggestions?
THX!
AJay
Old 12-04-2015, 07:25 AM   #13
THX!
AJay
Go for it, been good so far, no problems getting it activated, did it automatically, I would update it and then later do a clean install, not really necessary but if you have the time..
Old 12-05-2015, 12:35 PM   #14
Thanks FV!
Old 12-09-2015, 04:02 PM   #15
Meh, haven't gotten to it yet. I need to upgrade my version of Acronis and Kaspersky (how are these guys going to make money if Win10 lasts a while?!).
