Old 12-12-2015, 02:12 PM   #1
Miles
Well I'm Finally Giving in To Windows 10
Hi Everyone,
I am on call quite a bit from home and I will have to keep Windows 7 on one of my rigs out of necessity and the software and VPN I work with.
I'm planning to upgrade the device in my signature to Windows 10 and add a few other items. I need a little bit of help from my friends here at ABX
Should I do the update and then a clean install or should I go with the new full clean install without doing the update? Do you guys really like Windows 10 better than 7?
I read here that some of you were able to install Office 2010 on Windows 10, is there a special trick to this?
Ken, I'm leaning toward one of the new Dell's either the 34 like you purchased or the brand new UP2716D. I have an Asus 970 Strix OC will that be adequate for the 34 if I'm not using it for any heavy gaming or will I need a 980?
Any other advise will be greatly appreciated.
I've missed you all!
Miles
________________________________
Intel 4690k| ASUS Z97 sabertooth| 16GB Kingston DDR3|ASUS GTX 970|Samsung 850 Pro 512GB SSD | 1 - Seagate 2 TB Barracuda ES | Seasonic 650 watt Gold PSU|Fractal Design Arc Midi rev 2| Windows 7 64-bit Professional | Eizo CX-241
Old 12-12-2015, 04:48 PM   #2
Re: Well I'm Finally Giving in To Windows 10
Hi Miles good to see you posting, your 970 will be perfect for the 34" Dell (great monitor by the way).....I just did the upgrade and was perfectly happy with it, the only reason i did a clean install is because of my new Samsung 950 Pro...really liking W10...wouldn't go back to seven..I have Office 2013 installed with no problems, I even have Quicken's 2009 installed and it works just fine. Keep us informed on now things are going, always good to hear from!
Old 12-12-2015, 08:04 PM   #3
Nice monitor Miles, can't wait until I get a Dell. Windows 10 is OK but first time I'm having browser issues with IE11 and Edge. You should have no problems running Office 2010. Good luck!
Old 12-12-2015, 08:12 PM   #4
GWillakers
Originally Posted by Miles View Post
Hi Everyone,
If you are intending to utilize the free upgrade, I think you had to upgrade first, and then later you could do a clean install.
I think that might have changed with the "Threshold 2" though.
Supposedly one can use the Windows 7/8/8.1 keys to do the clean install.
Do note though, I ran into a bit of trouble when I upgraded my system,
then swapped in a new SSD for the OS, and tried to do a clean install on the
new SSD. Activation balked.
There was some talk, as things might have been better if I signed into a Microsoft account.
Internet/Gaming ASUS P9X79 WS/BIOS 4802/Intel XEON E5-1650 V2 3.5GHz (4.4 GHz O/C) 6 Core/12 Thread - 12MB L3/Intel Stock AC Cooler/Antec P180 case/Thermaltake Smart M 850W PSU/4x8GB Kingston KVR16E11/8I/PNY GTX 1070 8GB graphics card/System drive Samsung 850 Pro 512GB/Data drives Intel 520 series 240GB/Intel X25-M 80GB/Windows 10 Pro (64-bit)
WorkStation SuperMicro X9SRA BIOS 3.2/Intel XEON E5-2687W 8C/16T (3.1 GHz -3.8GHz) 20MB cache/Noctua NH-U12S/ASUS GTX 970 STRIX graphics card/Thermaltake core X5 EATX Case/Antec Earthwatts 650 PSU/4x8GB Kingston KVR16E11/8I/System drive Samsung 850 Pro 512GB /2x Seagate 3TB ST3000DM001/1 TB Seagate/Windows 10 Pro 64-bit
Old 12-12-2015, 08:31 PM   #5
Yes I had no problems by signing in with my ms account.
Old 12-13-2015, 12:31 PM   #6
Miles
Thanks everyone I read the advice you are giving, but I am not as trustworthy of articles as I use to be. You just can't beatr first hand experience and I trust my buds here implicitly!
Miles
Old 12-13-2015, 12:49 PM   #7
Your welcome Miles and by the way Have a Great Christmas.
Old 12-13-2015, 12:53 PM   #8
When you install Win10 don't select 'use preferred preferences' and you can customize it a bit like choosing which browser to use like IE11 or Edge. You should go with Edge to see what it is like, you can change later.
