Old 01-08-2016, 12:19 PM   #1
raging bull
raging bull's Avatar
motherboard diagnostic?
think i might have a motherboard problem with my asus z77. looks like some of the usb 3.0s dont work right. anyone have a suggestion for a motherboard diagnostic? thanks.
Asus Z97/i5-4690k/16GGSkillTrident1866/256GSamsung840SSD/WD1T/RX9-270X/Win8.1
MacAir/iMac
P8Z77-V/i7-2600k/16GCorsairVengeance/128GSamsung830SSD
P6Tdeluxe/i7-920(2.66)/3x2G-CorsairDominatorDDR3-1600/WD640CaviarBlack/SamsungF1-1T/Asus4870-1GDarkKnight/Corsair850TX/LianLiB25B/Samsung22xDVD/VistaUltimate64
Lenovo T500/Win7/
P5KdeluxeWiFi/E6750(2.66C)/2X1G-Mushkin DDR2-1066/T2x320GB SeagateBarracuda/Corsair520HX/LianLiA16B/Vista
P4P800e/2.4c@3.1/2x1G-OCZ5001024ELGEGXT/WD36/WD200/RadeonHD3850AGP512MB;Enermax 465
two T500s
T61
; Dell e1505; Dell Inspiron4000;Dell Dimension 4100
Old 01-08-2016, 04:57 PM   #2
Re: motherboard diagnostic?
It could be several things but it should be easy to troubleshoot. You can check Device Manager and see it the driver is present. I don't know what OS you are running but if the USB ports were working before and stopped working and you haven't went into BIOS and made any changes then I would go here and search for USB 3.0 Problems and your correct OS and look for the 'Fix It' app.
https://support.microsoft.com/en-us
Corsair 760T Arctic White / ASUS ROG RAMPAGE VI APEX / Intel i9-7900X / ASUS ROG-STRIX-GTX1080-O8G-11GBPS / Corsair Dominator Platinum 32GB (4 x 8GB) DDR4 DRAM 2666MHz C15 / SeaSonic Prime 750W Titanium / ASUS ROG SWIFT PG348Q / Intel Optane SSD 900P 480GB / Samsung 960 EVO M.2 500GB / Samsung 850 Pro SATA 1TB / Ducky Shine 3 YOTS / Razer DeathAdder Elite / ASUS OC Panel / ASUS Essence STX / Audioengine HDP6, N22, S8 / AKG K712 PRO
Old 01-08-2016, 05:24 PM   #3
See if they are the Intel ports or asmedia ports, the asmedia ports on my MB work on some things and not on others? Known problem!
Old 01-08-2016, 08:38 PM   #4
raging bull
thanks! the usb 3.0 sockets dont work. best as i can tell, that means i need a new motherboard. oh well....
MacAir/iMac
Lenovo T500/Win7/
two T500s
T61
Old 01-08-2016, 08:58 PM   #5
raging bull
i uninstall the 3.0s and let the device manager find the 'new' hardware, but i get a code 31 on the usb 3.0s. checking the 'net, looks like i'm not alone. but i dont know why this should be an issue after four years with this MB.
MacAir/iMac
Lenovo T500/Win7/
two T500s
T61
Old 01-08-2016, 09:03 PM   #6
Just get a $20 usb 3.o add in card ...easy way to go, I did that before and works great... lots cheaper than a new MB!
Old 01-09-2016, 07:56 AM   #7
raging bull
i was just going to ask about a new z77; dont see 'em listed in stock anymore on newegg.
i've got enough 2.0 slots, and a couple of 3.0s that still work. just figuring if one thing goes, then something else is going next....
thanks.
MacAir/iMac
Lenovo T500/Win7/
two T500s
T61
Old 01-09-2016, 09:20 AM   #8
You have 2 ASMedia blue USB 3.0 ports in the rear and 2 Intel blue USB 3.0 ports in the rear. There are also 2 internal Intel USB 3.0 ports on a header.
Sounds like you are having issues with only a couple of USB 3.0 ports so my guess would be the ASMedia ports in the rear. You should see the ASMedia USB device listed here if you have the driver installed properly.
If you see this then there is a chance the controller went bad.
Old 01-10-2016, 10:55 AM   #9
I can't stand to have any issues with my mobo or any part of my singular PC. I would replace something if it was not working even if I were not using it. Seeing how this is an older mobo and probably not easily replaced you might want to try and add-on USB 3.0 card like FVB said. Myself, I only have 2 USB 3.0 devices, a thumbdrive and a mechanical hard drive that does not benefit from USB 3.0 anyway. My rear USB 3.0 ports all have 2.0 devices plugged in. I guess that might be your dilemma, you just need the extra USB ports but they don't have to be USB 3.0. There is a bracket that you can get that will connect to your internal Intel USB 3.0 header give you two more USB 3.0 ports in the rear (if you are not already using the port for the front case).
50cm Two USB 3.0 Female Back panel to Motherboard 20pin cable with PCI bracket - Newegg.com
Old 01-10-2016, 01:00 PM   #10
raging bull
thanks.
i've updated the 3.0s from the asus website....and they seem to work for a while...but the updates dont 'stick.' when i reboot, same problem.
not really a big deal, but i've had several bsod the past week too, which leads me to believe there's a bigger issue.
MacAir/iMac
Lenovo T500/Win7/
two T500s
T61
Old 01-10-2016, 01:08 PM   #11
thanks.
Do you have the latest bios?
Old 01-10-2016, 01:12 PM   #12
raging bull
havent updated bios since 2012. my philos has been if it aint broke, dont update. but maybe i should here....
MacAir/iMac
Lenovo T500/Win7/
two T500s
T61
Old 01-10-2016, 01:25 PM   #13
Yes your right, seems like its broke so update the bios...really nothing to loose. back up first...lol
Old 01-10-2016, 02:36 PM   #14
That is an older system, I would try cleaning it for 10min. Blow it out, reconnect all the power connectors and reseat the CPU. Those are all free checks you should do after that long of a time. It will only help.
Old 01-11-2016, 06:58 PM   #15
raging bull
ok! i'm on it, wise one.
MacAir/iMac
Lenovo T500/Win7/
two T500s
T61
