Old 03-15-2016, 08:56 PM   #1
System suddenly doesnt display anything. Powers on though. Please help.
My PC is suddenly acting up. It doesn't show anything. Not even the bios screen or logo appears. When i power on the power LED glows and the HDD LED glows for like 5 secs or so as if its booting and after that only the power led is on. The heat sink fan is running. No display however.
I tested the monitor on another system and its OK. I tried pulling out the graphics card and tried hooking the monitor to vga output from the motherboard directly. Still no display. I don't think the system is even booting because the HDD led glows for only 5 secs after powering on. I tried pulling out the memory sticks n trying them one by one. Disconnected all my HDDs and tried with only one. Removed the CMOS battery and put a new one back in after 20 mins to reset the BIOS. Still same results.
Can any of you help to troubleshoot the problem please ?
Old 03-15-2016, 09:09 PM   #2
Re: System suddenly doesnt display anything. Powers on though. Please help.
What power supply do you have and how old is it?
Old 03-15-2016, 09:44 PM   #3
Things I would start doing is checking power supply connections, reseat the memory or take half the sticks out, reseat the CPU. If you can get into BIOS I would reset it. Also check the voltages in BIOS for your power supply and make sure your hard disk is seen.
Alot of modern mobo's will beep is something is not working right. For example, two beeps means its a memory problem, etc (read troubleshooting in the mobo manual). Some boards come with a BIOS post code LED to show where the problem lies.
Good luck.
Old 03-16-2016, 12:47 AM   #4
Hi how are you doing !
The power supply must be at least 4 years old. But used only for about 200 days maybe with just a few hours on those days since that entire PC is only for video edits and gets used maybe once a week kind of since it was assembled.
Old 03-16-2016, 12:53 AM   #5
Good luck.
Hi Sandog,
There was no BIOS beep error. There is zero signal to monitor being output. Not even a blink. So theres no way of seeing BIOS screens etc. But it powers up and the fans inside are running. The mobo internal led on the board is glowing. Hard disks are running (can feel them). The pc case external power led is also glowing. HDD led glows for about 4-5 secs when i power on, after which its off only. I yanked out the nvidia graphics card and tried booting with MB VGA output yet no results.
Old 03-16-2016, 07:57 AM   #6
Try a different video card if you have one.
Old 03-16-2016, 10:55 AM   #7
I removed the graphics card and tried booting with the on motherboard dsub connector hooked to the monitor. Didn't Work.
Old 03-16-2016, 11:15 AM   #8
Maybe a bad CPU, there is no beeps with dead CPU, mobo will
light up, and fans will spin up, older HD will light up.
Even some times with things lighting up a PSU can still be bad.
Old 03-16-2016, 11:26 AM   #9
Heres another if the PC for all intents is working, i.e. front panel lights, HDD spins up, optical drives have power,
fans start whirring, but there's no beep, the motherboard can also be the culprit...
Old 03-16-2016, 11:30 AM   #10
What would happen if the bios battery was dead?
Old 03-16-2016, 11:32 AM   #11
If it was me I'd look hard @ mobo/cpu. The mobo being 4 yrs old,
a part on it could of failed just from age... Cpu being the least likely
of the two to go...
Old 03-16-2016, 11:40 AM   #12
A dead bios battery will usually only cause the system to not save bios settings, and not keep time/date.
Old 03-16-2016, 11:51 AM   #13
Thanks Skully.....it was just a thought...lol
Old 03-16-2016, 12:04 PM   #14
exc
Along with what Skully suggested, I also think you have to get into the bios to change a setting for the system to recognize the switch from "video card" to "on board video"!
Since you can not see anything on the monitor, if you have another video card, I would try that also.
But you stated that you removed the battery for 20 minutes and did a "CLR CMOS" so I do not think it is video related.
Bad memory module - you should still be able to get into the bios.
Most of the new mother boards - cpu not even required to get into the bios.
Power supply - is indeed required to get into the bios unfortunately.
Optical drive, or hard drives. even if bad you should still be able to get into the bios.
But, if you want to test the hard drive or optical drives, pop them into that other system you tested the monitor on, set them as slaves and see if they are recognized.
Good luck and keep us posted.
Excaliber!
Old 03-16-2016, 01:28 PM   #15
Try starting up without any hard drives, A working mobo only needs
a video card / memory/PSU/CPU... to go into the bios...
