Old 01-06-2017, 11:13 AM   #1
Is it possible to burn a CD iso to a blank DVD ?
Id like to know if its possible to copy a CD to ISO image and then burn that image onto a blank DVD instead of a blank CD.
The CD is a bootable rescue disk for backups. I just want to copy it, but instead of on a blank CD, id like to copy it onto a blank DVD. Reason - Im on the outskirts of the city and dont have access to blank cds at the moment but have loads of blank DVDs lying around.
Old 01-06-2017, 12:48 PM   #2
Re: Is it possible to burn a CD iso to a blank DVD ?
Its worth a try...don't have much to lose?
ISO to Bootable DVD Converter - How do I convert ISO to Bootable DVD with WinISO?
How To Make a Bootable USB, CD or DVD to Install Windows Using an ISO File
Asus ROG RAMPAGE VI APEX - Intel I7 7820K Cooled by Noctua NH D15S - 32 Gigs Corsair Dominator Platinum CMD32GX4M4A2666C15 - Asus GTX 980 TI Strix - Intel Optane 900P 280 gig for OS - Samsung 950 Pro 512 Gig Steam Library - Samsung 840 EVO 500 gig data - 1 TB WD Black data - Corsair 540 case with Corsair HXi750 PS - Dell UltraSharp U3415W 34" monitor - Ducky Shine 5 RGB Keyboard - Mionix Naos 7000 mouse - AudioEngine A5+ Speakers driven by Asus Xonar U7 MKII USB sound card - AKG 7XX Red Limited Edition Headphones ....and some other stuff!
Old 01-06-2017, 09:56 PM   #3
No, i actually tried and it didn't work. After that only did i decide to ask here because i couldn't find anything specific to this nature of problem on google. Nero rejects the blank disk saying "this disk is not suitable for burning this project, please insert the correct type of disk" etc.
Its only after i tried different combinations, copy a DVD, copy a CD, etc. It makes the .nrg image file, but then its unable to burn it onto the DVD by citing the above error.
I read your link and incidentally have even tried WinISO before posting for suggestions. The CD is actually a bootable CD, its a rescue media disk. So win iso was able to make the iso. But Nero burn program rejects the blank disk saying its not a right type of disk.
But i havent tried that SET BOOK DISK option. But i dont have a separate .BIF file. How do i get it ?
Old 01-07-2017, 09:20 AM   #4
Use windows not nero to burn the disc...try it!
Burn a Disc Image from an ISO or IMG file in Windows 7
Old 01-08-2017, 08:30 AM   #5
Im using Win XP not windows 7. My business PC is a bit of a dinosaur. So anyway i did this successfully and to recap how, I took an image using CDBurnerXP software. Its a free program. I made an ISO and then burnt that ISO using the same program and it worked. Weird how a 'name' program like Nero couldn't do this.
Old 01-08-2017, 09:51 AM   #6
Glad you got it done, I forgot about that burning software, its a good one!
Old 01-09-2017, 08:58 PM   #7
Thank You !
