Old 07-04-2017, 10:08 AM   #1
50 gigs of temp files Locked...HELP
Well I just noticed my used space on C drive has been gping up so I ran Disk Cleanup and found 50 gigs of Temporary Internet files but it has a lock on it and won't delete the files/ I've been on google for a day or two looking for a fix but nothing works, so if anyone has a idea, please let me know? Thanks in advance...
Old 07-04-2017, 10:23 AM   #2
JimTram
Seabees, USN (Retired)
JimTram's Avatar
Re: 50 gigs of temp files Locked...HELP
Restart in Safe Mode and try.
CyberPower CP1350PFCLCD
Sennheiser HD280 Pro
Win10 Pro 1703
Old 07-04-2017, 10:32 AM   #3
Thanks Jim I tried that yesterday....no luck? By the way happy 4th to you and your family!
Old 07-04-2017, 10:39 AM   #4
JimTram
JimTram's Avatar
Uninstall Chrome and see what happens.
Win10 Pro 1703
Old 07-04-2017, 10:41 AM   #5
JimTram
JimTram's Avatar
BTW, what are the names of some of the files?
Win10 Pro 1703
Old 07-04-2017, 10:42 AM   #6
Thanks I'll give that a try!
Old 07-04-2017, 10:43 AM   #7
I used this %temp% and it got rid of a few files but my temp folder doesn't have any where near 50 gigs of files?
Old 07-04-2017, 11:01 AM   #8
Tried uninstalling chrome and ccleaner and still no luck....here's a screen shot of Disk Cleanup and when you select look at files when you select temporary internet files it opens the file explore and this is what I see....nothing
Old 07-04-2017, 11:22 AM   #9
JimTram
JimTram's Avatar
Make sure in Explorer you have the view settings so you can see both hidden and system files.
Win10 Pro 1703
Old 07-04-2017, 11:28 AM   #10
I have it just like that.
Old 07-04-2017, 11:38 AM   #11
JimTram
JimTram's Avatar
Given MS's track record - it could be a flaw in the file calculations within Disk Cleanup?
Win10 Pro 1703
Old 07-04-2017, 11:41 AM   #12
Yeah but before that Creators update my system was around 140 gigs now its at 209 gigs....something is going on?
Old 07-04-2017, 11:48 AM   #13
JimTram
JimTram's Avatar
You should have deleted manually the backup of the pre update OS, and whatever restore points associated with it. MS makes a backup of the files.
You may want to manually invoke System Automatic Maintenance.
Win10 Pro 1703
Old 07-04-2017, 01:04 PM   #14
How do I invoke SAM? Never mind I found it.
Old 07-04-2017, 04:11 PM   #15
I have an Intel Firmware update file that I cannot get rid of. I have it stored in my Win/Temp folder now. After files are greater than 30days old I believe Windows will delete them. I found no way to delete my file BTW, I tried CCleaner and it couldn't empty the Temp folder nor Safe Mode.
Corsair 760T Arctic White / ASUS ROG RAMPAGE VI APEX / Intel i9-7900X / ASUS ROG-STRIX-GTX1080-O8G-11GBPS / Corsair Dominator Platinum 32GB (4 x 8GB) DDR4 DRAM 2666MHz C15 / SeaSonic Prime 750W Titanium / ASUS ROG SWIFT PG348Q / Intel Optane SSD 900P 480GB / Samsung 960 EVO M.2 500GB / Samsung 850 Pro SATA 1TB / Ducky Shine 3 YOTS / Razer DeathAdder Elite / ASUS OC Panel / ASUS Essence STX / Audioengine HDP6, N22, S8 / AKG K712 PRO
