Old 07-10-2017, 09:37 AM   #1
Will Windows 7 64Bit accept a new 4TB drive ?
Hi Guys,
I have just ordered a 4TB drive online. The drive has been shipped to me. When it arrives i have 2 systems to test it on. A Win XP 32Bit system and a WIN 7 64Bit system. I also have a USB 3 ext HDD docking station. Which will be the best method to test that the Hard Disk is working correctly ?
I think the WinXP 32Bit system cant read disks larger than 4TB. Im sure Win 7 64Bit can , but will it be able to format and test a disk with HD Tune etc when hooked to it via USB dock ?
At worst can i plug it to internal SATA and format it as 1 complete 4TB disk using basic inbuilt WIN7 tools or would i need any special program to do the GPT formatting ?
Thanks in advance.
Old 07-10-2017, 10:15 AM   #2
Re: Will Windows 7 64Bit accept a new 4TB drive ?
I found this, it looks like you need to use GPT for a drive over 2.2TB....and this is on windows 7
"Intialize it as MBR. This format, which has been around since the DOS days, is good enough for any drive below 2.2 terabytes.
You need GPT for drives larger than that, Windows 7 or Vista (I think) to read a GPT disk, and a motherboard with UEFI instead of BIOS to boot from one. These motherboards are currently few and far between."
Here's some more info...
Whats the Difference Between GPT and MBR When Partitioning a Drive?
Old 07-10-2017, 12:31 PM   #3
I should initialize it as MBR or GPT ? Will the GPT initialize menu be available within Win7 64Bit. I dont have a 4TB drive ready to see if that works. But when this 4TB drive arrives i wont have much time to test it due to return policy. Thats why im just trying to get to know how to do this.
Old 07-10-2017, 02:14 PM   #4
I would use GPT, like the link says, if you want the OS to see all 4 TB!
Old 07-10-2017, 11:10 PM   #5
But is there a GPT format option available in Win7 64Bit itself or do i need some external program ?
Old 07-11-2017, 08:04 AM   #6
If you where to go with Windows 10 and MS Media creation tool it does it in GPT automaticly but if you are going to W7 you can use this tool to get GPT. If you have the .iso file for windows 7 you can use Rufus to load that file in GPT mode on a thumb drive to install W7 on a GPT partation.
Rufus - Create bootable USB drives the easy way
Old 07-11-2017, 11:17 AM   #7
I will be installing Win7 64bit only on a 500gb separate drive. All my drives ae under 2TB. Except this new disk which will be 4TB so i intend to keep all other disks under MBR and only have the 4TB disk as GPT. Is that possible ?
On a side note will my older OUTLOOK 2017, Outlook Express, Office, Excel etc still install with the new 64Bit OS even though they are 32 bit programs.
Old 07-11-2017, 11:20 AM   #8
I'm using Quicken 2009 which is 32 bit with no problems on W7 or W10 64bit.
Old 07-11-2017, 11:27 AM   #9
Maybe this tool will do the job....
What Is GPT | How to Partition GPT Disk - EaseUS
Old 07-23-2017, 01:26 PM   #10
Thanks for the inputs.
Old 08-23-2017, 01:20 AM   #11
Just for the record and for others having the same kind of question. You dont need any third party tools in Win 7 64 bit when installing a raw disk it asks if you want to use GPT partitioning. Just give ok and your done. You get the entire 4TB as one partition to use. Ofcourse you can divide it by smaller partitions if you needed it that way.
