Old 10-18-2017, 12:32 AM   #1
Spanned Drives, Suddenly Vanished, But Showing In Disk Manager Labelled As Failed.
I have two 2TB drives. I made a partition on each for 1.5TB (DATA & MOVIES). So now both the disks have half Tb on each free ? I spanned those two unallocated volumes to form a 1TB volume MEDIA.
This setup was working for about a week.
Today the disks suddenly disappeared from under My Computer.
However they show up under disk management.
Ive attached an image of how the Disk Manager view looks.
Does this mean the disks are corrupted ?
I also found that if i unplugged and replugged the sata cables they come back online and looks ok. But then it fails again after sometime. Data is safe as i have a backup image of everything.
Should i just format and skip using SPANNED option ? Or is this more of a cable fault. The problem is all the cables sit in their ports so wobbly and not at all a solid locking. So much for technology design and ASUS mobos. All the plus sit sorta loose and shaky only. Theres nothing i can do about that because that's the mobo and the standard SATA cables.
Old 10-18-2017, 12:39 AM   #2
Re: Spanned Drives, Suddenly Vanished, But Showing In Disk Manager Labelled As Failed
In the image you can see the DATA partition even though its on disk 1 whose left over was spanned to the disk below. The DATA partition seems to work as normal. Its .5TB which was spanned with the 2nd disk to form MEDIA shows as failed. And the 2nd disk which had MOVIES partition on it failed along with its .5TB balance which was spanned to form partition MEDIA.
So im guessing disk2 must be having a loose contact or so because the un-spanned partition of disk1 "DATA" is still working.
Old 10-18-2017, 06:10 AM   #3
I also see the "Missing" message on that 2nd disk.
Can you replace the SATA cable on that one with a new one, or one that you know is good?
Old 10-19-2017, 01:11 AM   #4
As guessed it was a cable issue i suppose. I luckily had few brand new sata cables (im accruing my own little computer shop, ).
However after cable replacement its working and i could get the spanned drives back together by selecting import foreign disk on the deactivated one within disk manager. I also did another quick backup, in case terror decides to strike back.
Old 10-19-2017, 05:12 AM   #5
Good news !
Old 10-19-2017, 11:00 AM   #6
Yea glad to hear ya fixed your problem...
Old 10-19-2017, 11:57 AM   #7
'WE' fixed the problem.
Thanks a lot !
