Old 01-24-2002, 09:47 PM   #1
Racer78
Northwood Club
P4T-E How t update to 1005e with a northwood
My P4T-E came with 1004. I Found that by going to jumper mode and setting the jumpers for my cpu i was able to boot and flash the bios to 1005e. I then reset back to jumperless.
Keith
Old 01-24-2002, 09:48 PM   #2
Racer78
Northwood Club
P4T-E How do you install drivers for 850 chipset?
I can't seem to get them to install from my Asus CD> Thanks
Keith
Old 01-24-2002, 10:29 PM   #3
myckee
Now you tell me there is a way to flash it...after a big pain in the *** it cost me to eventually get it done with a 'willy'.
Well I'm using windows XP and the drivers are already there. I didn't need to use the supplied disk.
Old 01-24-2002, 10:56 PM   #4
Racer78
Northwood Club
I figured it out by trying it with nothing to lose
Darn Mwave said they would flash it to 1005! We will be chatting
Keith
Old 01-25-2002, 07:42 AM   #5
Miles
Thumbs up
That's a great piece of news Racer78:eek: I'm glad to see someone from this forum figured it out Did I hear someone say:
ASUSBOARDS.COM & RACER78 RULE
Miles
________________________________
Intel 4690k| ASUS Z97 sabertooth| 16GB Kingston DDR3|ASUS GTX 970|Samsung 850 Pro 512GB SSD | 1 - Seagate 2 TB Barracuda ES | Seasonic 650 watt Gold PSU|Fractal Design Arc Midi rev 2| Windows 7 64-bit Professional | Eizo CX-241
Old 01-25-2002, 08:28 AM   #6
Racer78
Northwood Club
Thank you
Old 01-25-2002, 09:20 AM   #7
bobmitch
bobmitch's Avatar
That is GREAT news! Wish I knew that on 1/11. No harm anyway...bought from my shop and the tech was already aware of the problem and had a "Willy" ready to go. Been running the 2.0a ever since...great processor.
Bob
Old 01-26-2002, 07:26 AM   #8
David Rolfe
David Rolfe's Avatar
Question Core Voltage?
That sounds good, but I didn't think the jumpers let you actually redefine a lower core voltage, which I though was a requirement for the Northwood (and one of the main reasons for the BIOS upgrade)?
Thanks,
-David-
Old 01-26-2002, 07:58 AM   #9
Welcome to AsusBoards.com David!!
The computer will always apply the default voltage that is indicated by the VID (Voltage Identification Definition) on the CPU at POST, so there is no risk for it applying too high a voltage to the Northwood, since the Willamette shares the same VID specification with the Northwood.
-kONGO
Old 01-26-2002, 09:59 AM   #10
Racer78
Northwood Club
I get lucky sometimes. Realy i hated the prospect of pulling the Willy out of my friends computer.
I mean really, how do i get it over here? "Hey dude, better bring your box over so i can check the artic silver on your Willy"
Later All,
Keith
Old 01-27-2002, 08:12 AM   #11
David Rolfe
Question Jumper settings?
Hi kONGO,
Thanks for your reply, and for welcoming me to the site!
Could you, or some other kind person, possibly advise me of the appropriate jumper settings required to let me boot up my new P4T-E (BIOS 03) fitted with a 2A GHz Northwood, so that I can update the BIOS to the latest Version 05?
Thanks in anticipation,
-David-
Old 01-27-2002, 08:47 AM   #12
No problem. Checking the manual (you can download it here) and knowing it's a 2GHz CPU - which means 100MHz FSB and 20.0x multiplier - I put toghether this image:
That's the way the jumpers should be set for the 2GHz Northwood. Please correct me if I'm wrong .
-kONGO
Old 01-27-2002, 12:37 PM   #13
Racer78
Northwood Club
Kongo,
nice job
Old 01-27-2002, 12:41 PM   #14
Thanks . Mostly cut-and-paste from the pdf manual though .
Also, leave jumper 5 as it is, it's reserved in some way, so it's best not to touch it .
-kONGO
Old 02-16-2002, 06:37 PM   #15
Miles
BUMP
Miles
