Old 11-12-2002, 06:41 PM   #1
Miles
What Are Some of the Coolest Utilities You've Found
What are some of those cool utilities you've run into, yes those small little unobtrusive gems, things that have become part of your personal arsenal? Thanks in advance to all that participate!!!
Product: Ultimate ZIP
Use: File Compression/decompression
Type: Freeware
Impression: Excellent, appears to have as much or more functionality as WinZIP and also handles the extraction of RAR, ACE, and other popular file compression schemes
Site: Ultimate Zip
Miles
________________________________
Intel 4690k| ASUS Z97 sabertooth| 16GB Kingston DDR3|ASUS GTX 970|Samsung 850 Pro 512GB SSD | 1 - Seagate 2 TB Barracuda ES | Seasonic 650 watt Gold PSU|Fractal Design Arc Midi rev 2| Windows 7 64-bit Professional | Eizo CX-241
Old 11-12-2002, 06:44 PM   #2
jdmba
jdmba's Avatar
Hmmm
RENQ which is a prompted renamer is good.
MJOG which is a dos based calendering reiminder system is also good.
TextPad makes editing HTML and batch files and cue sheets, etc. very easy with superb macro's
MailWasher is great for dealing with spam without downloading it first and
SuperUtility by Kim Watt for the TRS-80 was fantastic
Old 11-13-2002, 08:42 PM   #3
Griff
Griff's Avatar
Have a look at Incredimail. Its a great email enhancer. WWW.incredimail.com
Obsidian 550 Corsair Case
Asus Motherboard P8Z77-V PRO
Intel i7-3770K Unlocked
Arctic Cooling Freezer 13
Samsung 840 EVO SSD For O/S
LG BlueRay Burner
Seagate1TB SATA for Photos
Built in Card Read
Win10 Pro
Old 11-13-2002, 09:10 PM   #4
Aggemam
Aggemam's Avatar
Product: Coolmonitor
Use: Various system monitoring
Type: Freeware
Impression: The name says it all, very kewl! - Not particularly user friendly, but work with it for a while and it'll unleash it's mighty kewlness... You can pratically monitor anything with it e.g. cpu/mobo temps, hd space, ram space, network status, you name it. Check out their forum, people have made scripts for alot of cool stuff. If you're hooked up to the internet 24/7, you can have the weather report, the tv-guide, Asusboards folding stats, live on display. The thing that distincts coolmon from other monitoring software, is that it's integrated with your desktop, so you'll have your info right in front of your nose. I love this progie.
Site: http://www.arsware.org/coolmon/
Old 11-14-2002, 07:16 AM   #5
Miles
Thanks guys, keep em coming
Miles
Old 11-14-2002, 08:18 AM   #6
Brian
Brian's Avatar
Thumbs up
I have this little app I use called Daily Rotation that you can configure to go to your regular daily internet sites by clicking the small icon in the system tray. I have about ten sites I visit every day no matter what and it's a little easier and quicker with this gem.
I've attached the program to this post...
Enjoy!
Old 11-14-2002, 08:31 PM   #7
Excavator
Looked long and hard for just the right synchroniztion program. I tested about 5 different ones and read about dozens.
SynchroMagicPro is the one I ended up with.
Lian Li PC-V2100B * Asus P5WD2 Premium w/0606 BIOS * Intel P4 EE 3.73GHz w/2MB L2 Cache, 1066FSB * Artic Cool Freezer7 * 2GB Corsair DDR2 800UL * 2 74GB Western Digital Raptors in RAID0 * WD SATAII 250GB w/16meg cache * WD SATA 120 Gig w/8meg cache * WD IDE 120 Gig w/8meg cache * WD IDE 80 Gig * Plextor 716A SATA DLDVD Burner * Creative 16xDVD/Rom * e-Geforce 6800GT w/256meg with two 20.1" Vuesonic VP201b LCDs * DTV/DSL Internet connection at 8 meg per/sec down and 768K per/sec up
Old 11-15-2002, 06:14 PM   #8
Miles
Bump for some more cool utilities
Miles
Old 11-18-2002, 09:19 PM   #9
bugsy_pal
I like:
- Registry Crawler - great for searching the registry
- TransMac - for reading Mac floppy disks on your PC
- ClipCache - multi-clipboard proggie
- KeyText - macro sort of program, saves typing
Cheers
Old 11-19-2002, 02:06 AM   #10
trashbyte
trashbyte's Avatar
These are my most used applications:
Games:
UT2003
Editors:
Ultra Edit
Text Pad
Professional File Editor 32
Assemblers, Compilers and such:
LabVIEW 6i
MS VS 6.0
MS VS .net
MASM
Communications:
WSFTP LE
Putty (SSH)
Tera Term Pro <-- Awesome!!!
Others:
Humminbird Exceed
MathCad
Scientific Notebook
Old 12-01-2002, 04:10 PM   #11
Miles
Time for a Bump
Miles
Old 12-01-2002, 05:40 PM   #12
Mikki
There's already a thread like this here
Old 12-01-2002, 06:07 PM   #13
SupDawg
SupDawg's Avatar
Ok, I cound a cool little program that converts print screens to jpegs automatically and placesd them on your desktop. You can specify the image quaility of the file via a slider on the gui. Nice compact and pretty cool. Glad that i found it.
The views expressed in this electronic dialogue are mine alone.
All physics are belong to me. " Kongo
Old 12-01-2002, 08:39 PM   #14
Griff
Griff's Avatar
Cool little proggy. Info here http://www.driverheaven.net/DHTOOL
Download here
http://www.driverheaven.net/downloads/2.1.2.6--FULL.zip
LG BlueRay Burner
Built in Card Read
Win10 Pro
Old 12-01-2002, 08:45 PM   #15
Sir_JaKoNT|L
an ASUSBoard fanatic
Sir_JaKoNT|L's Avatar
i was using incredimail, but it is too complicated for my simple daily emailing
so back with Office outlook
running rig
AMD ATHLON X2 4000+ AM2
Gigabyte GA-M61SME- SL2
2 x V-Gen DDR2 1GB RAM PC5300
WDC 160GB SATA2 8MB
Sony DVD R/W 20x
Enlight EN 4150 casing
Enlight True Power 420Watt PSU
Stick together team...
HTC Tytn II is the way!!!
