Old 02-10-2003, 11:48 PM   #1
moregolf
moregolf's Avatar
File System Q's Please
1. Can I convert a fat32 to NTFS and not loose any data?
2. If I convert to NTFS, will Ghost 2002 work with NTFS HDD's?
Thanks....
Old 02-11-2003, 07:53 PM   #2
diceless
diceless's Avatar
you can convert a fat32 partition to NTFS as long as the partition is not the boot or system partitions. Otherwise, you are going to need to backup and reinstall the OS to have those as NTFS. As for ghost 2002, no problems with NTFS drives.
Diceless
Old 02-12-2003, 11:26 PM   #3
moregolf
moregolf's Avatar
Thanks, it is the boot partition. Can I do a convert, then a repair by any chance....
Old 02-13-2003, 12:40 PM   #4
David Habermehl
Proud Dad
David Habermehl's Avatar
Unnecessary: See Microsft Knowledge Base article HOW TO: Convert a FAT16 or FAT32 Volume to NTFS in Windows XP.
<http://support.microsoft.com/default...b;en-us;307881>
All you do is open a command prompt and type
convert c: /fs:ntfs
Best regards,
David
Descarte meets quantum theory: I think, therefore I might be.
Old 02-19-2003, 09:00 AM   #5
moregolf
moregolf's Avatar
Thanks...
Old 02-21-2003, 08:55 AM   #6
Howard Stern_abx
King Of All Media
Howard Stern_abx's Avatar
Diceless
this is an incorrect statement, you can convert a fat 16 or fat 32 on the boot partition but using the convert command, it reboots a couple of time but it does work, it has worked since the NT4 days.
Intel quad I7 950 @4.2| Prolimatech Megahalems | Asus Rampage III Formula| EVGA GTX 680| 12 gigs of Gskill Sniper DDR3 - 1600 | Samsung 840 Pro | Creative X-FI Fatal1ty Pro | Corsair 850W PS | Samsung S27A950 | Lite-On Blu-Ray and Asus 24x DVD burner
Old 05-04-2003, 10:11 PM   #7
moregolf
moregolf's Avatar
I have a ghosted copy of this drive on another drive. After a conversion, can I access the backed up version? It is FAT32...Thanks.
(I don't want to loose any data.)
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
© 2006 - 2009 ABXZone Forums | About ABX Zone Forums | Advertisers | Investors | Legal | A member of the Crowdgather Forum Community
