Old 05-13-2003, 07:08 AM   #1
ThugsRook
ThugsRook's Avatar
HowTo: Download IE6sp1 to HD
for later installation (or burning to CD)
download the ie6setup.exe from MS to a new dir called C:\ie6sp1
http://www.microsoft.com/downloads/r...arch&ordinal=1
in the run command box type in
"C:\ie6sp1\ie6setup.exe" /c:"ie6wzd.exe /d /s:""#E" ...with quotes
choose your OS(es), download the files to your C:\ie6sp1 dir
to run the local files just click the ie6setup.exe
Old 05-13-2003, 01:08 PM   #2
Mikki
And it works perfectly...
Old 05-13-2003, 01:44 PM   #3
pointreyes
Just last week a person was asking about how to do this in Windows XP. Due to the superb documentation of how to do this, I have made this thread a 'sticky' for future reference. Good job, ThugsRook.
Old 05-13-2003, 02:44 PM   #4
Mikki
Yeah, good job Thugsrook.
[hehe, Sometimes having control is fun, Mikki. ]
Old 05-13-2003, 06:58 PM   #5
ThugsRook
ThugsRook's Avatar
LOL ~ thx for the sticky pointreyes
Old 06-04-2003, 11:01 PM   #6
Evil_abx
It's Not Easy Being Evil
Evil_abx's Avatar
Good job! This will save me a lot of time @ work.
Gigabyte SINXP 1394 / P4 2.53GHz / ThermalTake Volcano 7+ / Arctic Silver III / 2Gb Corsair Micro XMS / PC2700 CAS2 / ATI Radeon 9700 Pro / 80Gb Seagate Barracuda V SATA / Enermax 710B Case w / Window / Antec Tri Led 80mm Blue / 3 x ThermalTake Smart Case Fan II / Blue 12" Cold Cathode / Antec TruePower 550 / Sound Blaster Audigy / Black Panasonic 1.44 Floppy / 2.2Gb Orb Drive / 100Mb External ZIP Drive / Pioneer 16X DVD-ROM / 24x10x32 Creative CD-RW / CoolerMaster Rounded Cables / NetGear 10/100 5 Port Switch
Old 07-10-2003, 05:19 PM   #7
ralexand88
Yep
Old 06-21-2004, 04:00 PM   #8
rdmpe
A sandwich in every glass
rdmpe's Avatar
Is this for a complete install or just the service pack?
Hi! This may be just what I needed. A friend has a WinME machine w/dialup. She needs IE 6. Can I follow these instructions so she can just pop the cd in and install IE 6 directly from the cd? I'm not clear if the instructions are just for the service pack one or a full install.
Thanks,
Randy
Old 06-22-2004, 11:32 AM   #9
ThugsRook
ThugsRook's Avatar
this is the IE6 SP1 update.
download it, burn it to cd, and install it on any Windows comp you want.
saves alot of time for all those 56k'ers out there, and those that dont have Inet connections.
Old 06-23-2004, 08:12 AM   #10
Louis_abx
The White Wizard
Louis_abx's Avatar
Thanks, this works works amazingly well, just what I was looking for.
Louis
Old 07-26-2010, 07:49 PM   #11
sanjiwny
Re: HowTo: Download IE6sp1 to HD
