Old 06-06-2001, 04:46 AM   #1
jvidia
Question What is idle/load temperature ?
You all talk about idle and load temps ... but what are those temps ?
Ive got this readings with MBM 5 :
( idle ? ) with windows ME doing nothing 31 C ( min. )
( load ?) with windows ME after running 3DMark 2001 58 C ( max. )
Are those temps ok , or are they too hot !?
I think that the Golden Orb is not thaking advantage of the Arctic Silver II, because when the Orb is installed it must be tweasted and the termic paste is not well spread on the cpu core ...
Is there any cooler (not too expensive) that can be installed without tweasting and isn't so dificult to put on and take off as the generic Intel coolers ?!
Thanks.
My System
ASUS P6T Deluxe V2 | Intel Core i7 920 3838B079 | Corsair DDR3 Dominator PC3-12800 6GB
XFX GTX260 Black Edition | SB X-Fi Titanium PCI-E | OCZ SSD Vertex 60GB + WD WD6400AAKS | Plextor DVD-RW PX-716SA
Corsair HX620W Modular | CoolerMaster Stacker "All Black" | HP W2207h 22" HDMI
WC 3/8" by Apogee GTZ + BI GT Xtreme 240 + Koolance Nozzles + Station 600
Old 06-06-2001, 05:43 AM   #2
TeeDeck
TeeDeck's Avatar
Idle is just fine but I would say that your full load temp is a bit high. Mine runs around 45 when fully loaded. Might be what you said about the thermal paste not being applied correctly. That is not an easy process but it has to be done with care. Look at other post in the "Cooling" section, you'll probably find an answer to your question. All of posts have links to all sorts of coolers and heatsinks. Good luck.
"If the government hasn't taxed it, licensed it, or regulated it, it probably isn't worth much"
Murphy's Laws on Justice
Old 06-06-2001, 10:07 AM   #3
Asha_abx
Yeah you could reapply the thermal paste but remember every cpu is different. If your system is stable than it is mostly fine
I had an gorb, there is only one way to put them on right, otherwise the round sink part that should tough the cpu is resting on your socket, and it wont make good contact with the cpu surface.
grtz Asha
Celery 600 @ 1100, 2v., max 33c., 192 pc133 32257, Cusl2-c, watercooling and 80w. peltier.
Old 06-06-2001, 11:34 AM   #4
Ozzie
CRS Designee
Ozzie's Avatar
Also make sure you have good case ventillation.
Moving to cooling section...
Have you supported your forum today?
Change is the only constant in life
Old 06-06-2001, 12:27 PM   #5
patentman
Modded Person
patentman's Avatar
You`re lucky with your G-orb.
It`s not a good one,you know.You should have arround 47C at a 23 ambient in a stockHSF.
Replace it by another better one-I can`t recommend one,see related threads
Old 06-06-2001, 07:42 PM   #6
STALKER_abx
SUPER SAIYAN
P!!!800@1GHZ
OCZ GLADIATOR/DELTA/ASII
ROOM @28
IDLE @32
LOAD @38
MOBO @30
Look at this.
http://www.cluboc.net/reviews/heatsi...ator/index.htm
Old 06-07-2001, 04:24 AM   #7
jvidia
Question
STALKER isnt the OCZ Gladiator/Delta very loud 46.5dBA ?!
And the Delta is connected to the mobo or to the power source ( like a disk ) ?
My System
Old 06-07-2001, 07:14 AM   #8
STALKER_abx
SUPER SAIYAN
Whenever u put a "DELTA" on any HS its going to be loud ok. I don't have the DELTA plugged unto MOBO cause it draws too much power from mobo thus creating more heat and instability. I use a 3pin to 4 pin molex adapter for PS. I soundproofed my case too. I can still hear the whinning of the fan but, not unbearable considering i have the tv, ceiling fan, window fan on all the time its hardly noticeable. Plus i use a ducted pvc mod as well so i don't have a problem with noise as others do.
