Old 07-20-2003, 12:13 PM   #1
MaXimus[X-D]
OCZ Gold PC3700 255 fbs 1:1 stable on DFI 875Pro
Man im impressed with this memory sent the Corsair 2x512 pc3700 back cause it would not run near rated speeds on any of my canterwoods and got this Ram and its running flawless at 255 1:1 3,8,4,4 at 2.7 vdimm on a DFI 875 pro man i wish i had more vdimm sandra bench is right at 6000. Ill try the corsair again when i get tis replacement. ima run this speed a while and try 260
Maxi
DFI LanParty 875Pro
SLK900u (bolted) Heatsink
2.8c @ 3.4 245 fbs 1:1 divider@1.7v
2x 512 Corsair TwinX PC3700
Antec True Power 550 Watt PS
2 Raptor 36gig SATA 10krpm(raid 0)
2 WD 120 gig 7200 rpm 8Meg(raid1.5
2 200 7200rpm 7200rpm 8Meg (HotSwap)
2 120 gig WD se Ext USB
Ati 9800np modded to 9800pro
Audigy2
Pioneer Slot loader DVD 120s
Sony Dru500 4xs DVD burner
Logitech Z 680 5.1
Windows XP SP1
Old 07-20-2003, 12:16 PM   #2
JoeBar
Bite me if u can...
JoeBar's Avatar
Enjoy m8...
Asus P5WDG2 Premium rev. 1.02G
Intel Pentium D 920 SL94S Malay @ 4.31GHz cooled by Thermaltake Big Water 745
GeCube Radeon X1900XT combined with LG 1980Q (8ms) 19' TFT monitor
2 x 1GB Transcend DDR2-533 @ 770mhz
2 x 36.7GB Western Digital Raptors Raid 0 | 300GB Western Digital Caviar SE SATA
Creative Soundblaster X-Fi Xtrememusic combined with Cambridge Soundworks Megaworks 550 THX
Asus E616P3 DVD | Asus 1608-P DVD-RW
Thermaltake Kandalf black super tower with 4 x 120mm and 2 x 90mm blue led fans | Chieftec 550W Triple 12V rails - 120mm fan
Old 07-20-2003, 04:52 PM   #3
BadTA
I hate you!!! J/K
I cannot get above 235FSB. I am going to buy some PC3500 and a new P4 2.8c tonight and then we'll see which one is holding me back. I suspect it's the CPU. I thought the Malay procs were supposed to OC quite well. Oh well, we'll see.
Mark
Pentium 4 3.0GHz 800FSB || Swiftec MCX4000 w/80mm Sunon Fan|| ASUS P4C800-E Deluxe|| OCZ PC-3700 Gold 4 x 256 || Powercolor Radeon 9800 Pro || Turtle Beach Santa Cruz || Antec True Control 550W || WD Raptor 2 x 36GB RAID 0 || Lian-Li PC-75 || Viewsonic VP171B 17" LCD
Old 07-20-2003, 06:41 PM   #4
fevernova
hey badta, what's the prod code and fpo/batch code on your 2.8C. I'm having the same problem with my 2.8C. For some reason I can do 100 passes of test 4,5,6 in memtest at 243 fsb , but when I run prime95, it crashes. I have tried 236 fsb and it fails too. So i'm running at 233 fsb right now with my ocz 3700 gold.
Old 07-20-2003, 11:32 PM   #5
BadTA
PROD CODE: BX80532PG2800DSL6WJ
FPO/BATCH: L317A834
PACK DATE: 06/13/2003
Mark
Old 07-20-2003, 11:47 PM   #6
oczguy
oi
If you guys need me I am here to help
Proud OCZ employee, If you have any questions or concerns please feel free to drop me a email at
Old 07-21-2003, 12:01 AM   #7
eva2000
eva2000's Avatar
Re: OCZ Gold PC3700 255 fbs 1:1 stable on DFI 875Pro
Maxi
yup i have my OCZ PC3700 Gold @ 255mhz 1:1 2.5-4-4-7 or 2.5-4-4-8 and 3-4-4-8 on IC7
see
Old 07-21-2003, 08:46 AM   #8
MaXimus[X-D]
Great chart!!
looks like for prolonged stability in my case (which may need more airflow) that 253 is the top end now by prolonged i mean the unit up for several hours allowing heatsoak to take place and being benched and stressed playing games the only thing i dislike about these modules is they are not 512 meg modules BF1942 and Planetside both really like 1 gig
M*Xi
DFI LanParty 875Pro
Audigy2
Logitech Z 680 5.1
Windows XP SP1
Old 07-21-2003, 09:55 AM   #9
Maxbo
just visiting...
Maxbo's Avatar
Maximus, do you use the "fast" setting on the R/W timing in the bios? What does that do anyway?
Old 07-21-2003, 10:48 PM   #10
oczguy
please do tell
Old 07-22-2003, 09:52 AM   #11
incido
I've had the same reaction a lot of times and the only way for me to solv it has been to give the cpu more juice. So up the VCore a bit if you dare and see if stabilizes... It might run for like 1 hour instead of 10 minutes and then you'd know you're on the right way.
Old 07-22-2003, 07:42 PM   #12
oczguy
