Old 12-16-2003, 07:40 AM   #1
gilme
VirtualDub - Couldn't Locate decompressor for format 'DX50'
I've attached an image with the error message..
I've tried to open the movie "Requiem For a Dream" in VirtualDub,
and received that message.
I opened it in GSpot to see what's the problem.
It was writted that I have 3 compatible codecs, but 1 is not working properly: 3ivx.
So I downloaded it and reinstall it..
Anyway it didn't help. And in other programs the movie
did play (Media Player, BS Player) !!!!
What's wrong ??
Old 12-16-2003, 07:45 AM   #2
NightRhyme
Clueless.......
NightRhyme's Avatar
you need Xvidcodec maybe ?
Old 12-16-2003, 11:02 AM   #3
PCBruiser
DX50 is the codec for DivX 5 I believe. It is available from http://www.divx.com Also make sure you are using the latest version of VirtualDub, v 1.5.10 is the latest I think.
Old 12-16-2003, 05:47 PM   #4
gilme
Didn't help...
I've just downloaded the latest version of VirtualDub - 1.5.10,
and it didn't work on it either.....
I have the lastest DiVX and XViD..
What can cause the problem?
Old 12-16-2003, 05:55 PM   #5
PCBruiser
Maybe you can find the answer here http://www.3ivx.com/ I haven't looked over the entire site but ... they do have both a support and forum section.
Edit: I've been using VirtualDub for a few years and have found that it is particularly intolerant of any errors it finds. For example, if the 4CC ID info does not match exactly the encoding, VirtualDub chokes on it, where other video playing and rendering engines don't seem to mind as much. Do you have another video rendering engine? If so, try the video in that and see what happens.
Old 12-16-2003, 06:05 PM   #6
Zulee
Zulee's Avatar
http://www.vcdhelp.com
< ThermalTake Tsunami >< HiperGroup Type R 480W >< P4P800 >< P4 Prescott 3.2@3.8GHz, Idle: 39C, Load 55C >< Zalman CNPS7700Cu >< 2xDiamondMax10 250GB 16MB RAID0 >< Selectra PC3200 2x1024MB 1:1 235MHz, 2.5,3,3,6 >< LeadTek 6800LE (12x1/6) @ 420/900 >< SB Audigy >< NEC-ND3500A >< MX1000 >< Hyundai L90D+ 19" 8ms >
Old 12-17-2003, 04:04 PM   #7
gilme
No one has a solution?
or any suggestion..?
Old 01-23-2004, 02:48 PM   #8
devilx
Need to reinstall Divx5.11
I've the same problem and I used to installed the Divx5.11 codec from K-Lite Codec pack only. It's enough for you to play DivX in player but not enough to decode in VirtualDub. I installed the Divx5.11 bundle pack from DivX.com and now it works fine in VirtualDub
Old 01-23-2004, 06:36 PM   #9
calinb
Yes, codecs from codec packs are often questionable. Also, it's a simple matter to change the fourcc code in a video header to anything you please. The fourcc changer, avic.exe, is one way to do this.
You could try ffdshow. It's a versatile decoder.
- Cal
