Old 12-17-2003, 07:50 AM   #1
subman
subman's Avatar
Help !! Winamp 5 Final - videos play upside down !!
Strange problem -
On my daughters computer which consists of a BX chipset ASUS P3B-F with an ASUS 3800 TNT 2 display card Winamp 5 final plays the AVI files upside down - in other software like Media Player and PowerDVD they play fine.
Any one have any solution to this problem ? I tried fiddling with the settings in Winamp as well Display Properties - no luck. I tried reducing of the Hardware Accel setting in the Display properties.
Old 12-17-2003, 07:54 AM   #2
KingTermite
The Shade of Lazarus
KingTermite's Avatar
Did you try turning your monitor upside down ? It might help.
Sorry...couldn't resist.
I don't know what the problem could be, but the developers often answer questions on the winamp boards....you might try posting your problem over there too.
Bye Bye ABXZone.....Rest In Peace.
Old 12-17-2003, 07:55 AM   #3
Ec]-[oMaN
EeHHh
Ec]-[oMaN's Avatar
i might be wrong here but i think it has something to do with codex's
"Rudeness is the weak man's imitation of strength."
AMD 64 3200
DFI Lanparty Ultra-D 704-2
Ocz Plat.Rev2 pc3200
Sapphire x800gto2
WD 250gb/16mb
Ocz 420w Powerstream
Old 12-17-2003, 08:13 AM   #4
bkdamon
I was thinking he might have the Australian version....
Old 12-17-2003, 08:49 AM   #5
KingTermite
Watching the video down under?
Old 12-17-2003, 08:51 AM   #6
Vric
Vric's Avatar
LOL
Nah seriously, it's must likely Codec problem, wrong version or something (like divx 5.05 vid and you have 5.01 or something)
Pentium 4 2.8Ghz @ 3080Mhz
Asus P4P800 DX
2x 512mb OCZ PC3500
WD 160gig SATA 8mb
Asus Geforce 6600GT
Termaltake 420W PFC Power Supply
Silverstone TJ06 Case
Windows XP Pro SP2 DirectX 9.0c
Old 12-17-2003, 08:54 AM   #7
Ec]-[oMaN
EeHHh
Ec]-[oMaN's Avatar
since we are talking about codecs and video,does any1 know of a codec pack that is farely up to date and has no spyware???i installed a codec pack that contained many codecs i could run all types of video/sound without problems,but it contained who knows what and now i cant do a windows update,cant do a roll back cause i will lose stuff i need,so soon ill have to reformat,wohooo!!!!!
AMD 64 3200
Sapphire x800gto2
WD 250gb/16mb
Old 12-17-2003, 09:42 AM   #8
Ec]-[oMaN
EeHHh
Ec]-[oMaN's Avatar
also is there anyway to make winamp stay lets say in the top righthand corner perm,even if iam viewing a website and click on the webpage,this would be a nice feature while whatching a video or something
AMD 64 3200
Sapphire x800gto2
WD 250gb/16mb
Old 12-17-2003, 10:38 AM   #9
DOA
DOA's Avatar
Make sure the main window (not EQ, Playlist, etc.) is the active window and press Ctrl+A. Or right click WinAmp, click Options, then Always on Top. Not sure if this would apply when watching videos though.
Intel C2D E6420 @ 2.67GHz
Asus P5B Plus
4GB Crucial BallistiX PC2-6400 (4-4-4-12)
2x Seagate 320GB Matrix RAID
eVGA 7950GT KO 512MB
Enermax Liberty 400W
Creative Labs Audigy 2 Value
Windows Vista Ultimate x64
Old 12-17-2003, 10:42 AM   #10
Ec]-[oMaN
EeHHh
Ec]-[oMaN's Avatar
oh wow man ty the ctrl+a works like i wanted,thanks for the info
AMD 64 3200
Sapphire x800gto2
WD 250gb/16mb
Old 12-17-2003, 08:07 PM   #11
subman
subman's Avatar
Thanks for the replies - the first thing I suspected was the codec and I reloaded Divx 311 - no difference. Still upside down
I checked on Google and this seems to be a common problem - but no one has an answer.
Old 12-17-2003, 08:08 PM   #12
Ec]-[oMaN
EeHHh
Ec]-[oMaN's Avatar
isnt there a newer divx???you could try a new version and see if winamp still play upside down
AMD 64 3200
Sapphire x800gto2
WD 250gb/16mb
Old 12-18-2003, 12:03 AM   #13
subman
subman's Avatar
I got it to work right... I used divx 4.11 and that corrected the videos. I also tried a couple of ver 5.xx and they did not help. I ripped them with divx 3.11 so I thought that should have made it work right - it does with Meda Player and PowerDVD.
Thanks for all the suggestions and the jokes about this problem
