Old 12-21-2003, 03:55 AM   #1
Monk_abx
CCIE
Monk_abx's Avatar
OCZ 4000 Gold Abit IC7-MAX3 (attn: bigtoe)
What are the recommened memory settings (at 250FSB 1:1) with the GAT settings? I'm trying to tune my newly built system.
Old 12-21-2003, 04:27 AM   #2
bigtoe
here to help
bigtoe's Avatar
There are no recomended settings for GAT.
All GAT is are Dram Refresh options between 64uS and 64.They force the ram to work outside is normal paramiters.
See what you get stable and stick with it.
Got a question???
It may have already been answered!!!
Old 12-21-2003, 04:44 AM   #3
Monk_abx
CCIE
Monk_abx's Avatar
I have it running stable. I just tried to lower 1 of the latency timers (what do you know, it posted.)
Anyhow, I tried to fiddle with GAT and I had to leave everything on auto or it wouldn't post. I slapped in 2x 256mbyte mushkin pc3500 ddr and I could run them really low on the latency scale with GAT on F1 (fsb @ 250 / ram @200)
Anyhow, I'm really happy with OCZ's memory. I'm hitting 6000mbtye/s in sandra.
Old 12-21-2003, 05:04 AM   #4
bigtoe
here to help
bigtoe's Avatar
BH5 is pretty much the only IC that will take GAT settings, although, out new 3700Gold rev2 does well with GAT settings also.
Got a question???
Old 12-21-2003, 08:46 AM   #5
Shane5578
monk, i'm running same memory and timings as you.
i'm running rev1 (samsung), but yours should be rev2(hynix)
Old 12-21-2003, 09:26 AM   #6
bigtoe
here to help
bigtoe's Avatar
If your running OCZ PC4000 its all Hynix based.3700Gold was Samsung on rev1.
Got a question???
Old 12-21-2003, 09:53 AM   #7
Shane5578
i got my info from here
http://forum.abit-usa.com/showthread...pc4000+samsung
oczsupport
I just wanted to point out that a lot of memory manufacturers ( Including Twinmos / Corsair / Buffallo ) also use this Samsung PCB gerber on their PC4000, it is a popular PCB to use because Samsung knows their stuff when it comes to PCBs, unfortunately the gerber is over a year old and we have switched to something that should provide more performance ( top end speed ).
Old 12-21-2003, 04:28 PM   #8
Spec3
oczsupport
That looks like a bigtoe post to me
Old 12-21-2003, 06:48 PM   #9
bigtoe
here to help
bigtoe's Avatar
oczsupport
Samsung PCB..Hynix IC's...LOL.
We have had 3 PCB revisions on PC4000 and above.All use Hynix IC's
Got a question???
