Old 01-25-2004, 10:10 PM   #1
RMAT
RMAT's Avatar
Which to buy DFI or ASUS?
Hey guys,
I see that most of you guys are running ASUS p4800 deluxes. Not sure if I want to buy one of these or the new DFI Lan party boards.
http://www.newegg.com/app/ViewProduc...=BROWSE&depa=1
Any pros and cons of these boards would help. Keep in mind that I will be watercooling and space and locations of connectors are an issue.
- old pics
Asus P4C800-E deluxe w/CHC-A05 koolance chipset cooler, 3.2C @ 3.6 with cpu-200G koolance cooler, EVGA 6800 ultra 256mb, Koolance PC2-601BLW water cooled case, Antec truepower550, simpletech pc-3500 1:1
Old 01-25-2004, 10:22 PM   #2
Jorrell
Jorrell's Avatar
I had the same problem a few months ago and I ended up going with the DFI. It hasn't given me any problems. They're both good boards. I think the DFI ended up having a little bit better cpu voltage selections then the ASUS. However I would have liked it to have further vdimm settings.
Overall, both very good boards. I just like to be different. You will probably have more support on forums with any issues if you go with the ASUS though.
Old 01-25-2004, 10:30 PM   #3
FB
If i was in the market for a new system. I would get the DFI
just search this site and you will find a lot of info on it.
Old 01-25-2004, 10:31 PM   #4
RMAT
RMAT's Avatar
Yeah...i have been leaning toward the DFI for a while...especially after some of Bigtoes reviews. Prolly gonna pick one up. I've been an asus fan for a while and the p4s8x experience has kinda turned me off of asus. Thanks for the replies.
- old pics
Old 01-25-2004, 11:51 PM   #5
Sharkims
I won't bite, honest!
Sharkims's Avatar
DFI LanParty-B
Primary Rig:
ASUS A8N-SLI Premium || X2 3800+(280x9.5 @ 1.425v (2.7ghz)) - CNPS9500 LED || 2x1gb OCZ PC3200@440(2.5-3-3-10) || 2x eVGA-7800GT SLI || WD Raptors 2x36 RAID0 || Creative X-FI Xtreme Music
Old 01-26-2004, 12:26 AM   #6
pointreyes
I have the P4C800E-D and the DFI LanParty 875P A.
Both are great boards. I lean only slightly towards the P4C800E-D due to the vdimm but then again, I can't oc the P4C800E-D and yet I have a 2.6c oc'ed to 3.25 with OCZ4000 running at DDR500.
Old 01-26-2004, 03:22 AM   #7
Sharkims
Sharkims's Avatar
DFI LanParty-B has 3.3v vdimm, I'm pretty sure.
Primary Rig:
Old 01-26-2004, 04:00 AM   #8
DJD
A proud Labber
DJD's Avatar
Originally posted by Sharkims
DFI LanParty-B has 3.3v vdimm, I'm petty sure.
The NForce Lanparty can give 3.3 vdimm. The Pro875B gives 2.9, but has an easy to do vdimm mod.
-Coz big boys will never stop playing!
Old 01-26-2004, 04:38 AM   #9
FIZZ3
FIZZ3's Avatar
If I'm not mistaken, the DFI 875 Infinity is the same board as the Lanparty without the girly name and candy coloring.
It's also cheaper!
Old 01-26-2004, 04:39 AM   #10
Sharkims
Sharkims's Avatar
Yeah, if you aren't going to use onboard sound and show your case off as a work of glowing art. You could probably just get the: DFI 875P Ultra Infinity.
Primary Rig:
Old 01-26-2004, 06:00 AM   #11
RMAT
RMAT's Avatar
But all the kewl kids are kidding the lan party...hehe....well...i do have dual cold cathode uv lights in my system now. And all my water cooling glows due to the uv die. Also my ata cables glow. Might as well get a Mobo that glows too...
- old pics
Old 01-26-2004, 08:00 AM   #12
Mr Steveo
Stayed @HolidayInn Xpress
Mr Steveo's Avatar
Im switching to DFI here shortly. And the board you mention would be much more to my liking sharkims. No pumpkin orange colored slots!!
Unfortunately right now all newegg carries is the LANPARTY 875B . Any suggestions on some other good DFI retailers?
Hardware Siggy - Under Construction
Join me on Google+ at
Old 01-26-2004, 08:11 AM   #13
ps24eva
hold up I'm lost Mr.Steveo
isn't that the board to get?
if not
which is the good DFI to get?
Old 01-26-2004, 08:20 AM   #14
RMAT
RMAT's Avatar
zipzoomfly...but it is the 865pe chipset.
http://www.zipzoomfly.com/jsp/Produc...uctCode=246453
- old pics
Old 01-26-2004, 08:24 AM   #15
Mr Steveo
Mr Steveo's Avatar
if not
Im just starting to learn the world of DFI myself. But my understanding is that theres two lines of 875 late revision boards from DFI: The LANPARTY sereis and the Infinity series. Last I checked the LANPARTY series is the only one on newegg.
Ultimately Id be happy with either. But given the choice I can live without the tuti fruiti colors
