Old 01-29-2004, 05:29 AM   #1
hepp
Ocz 4400
Just found this on the OCZ site.
Anyone seen any reviews yet, or better still tried it.
Bigtoe,
I thought you said it would be PC4500 next, did it not pan out?
Br
hepp
SB61G2
2.4C@270
2x256 OCZ 3500(bh5) 5:4
Old 01-29-2004, 09:35 AM   #2
bigtoe
here to help
bigtoe's Avatar
The ram will do 283fsb but pretty much only on the P4C800 range of boards so we down graded it a little.What this has mean't is that I have been able to qualify it on many boards at 275fsb.
The ONLY board I was unable to qualify from my stock here was the IC7 MAX3 which as we all know has a few "issues"
The ram also works best by SPD which is pretty slack at 3-4-4-8 but it doesn't need much voltage and clocks like a champ.
I hit DDR606(just!!) with mine on the P4C800E.
Got a question???
It may have already been answered!!!
Old 01-29-2004, 10:11 AM   #3
hepp
Wow, what kind of benchmarks did that give?
Br
hepp
SB61G2
2.4C@270
Old 01-29-2004, 11:14 AM   #4
ps24eva
If you pump it with more volts is there anyway to do ddr600 at cas2.5?
Old 02-16-2004, 04:30 PM   #5
the_mei
Which ICs are on it ? Hynix Rev.C DDR500 ?
Old 02-16-2004, 04:48 PM   #6
RMAT
RMAT's Avatar
Where can you buy this? and how does it compare to corsairs xmx pc-4400?
- old pics
Asus P4C800-E deluxe w/CHC-A05 koolance chipset cooler, 3.2C @ 3.6 with cpu-200G koolance cooler, EVGA 6800 ultra 256mb, Koolance PC2-601BLW water cooled case, Antec truepower550, simpletech pc-3500 1:1
Old 02-17-2004, 07:33 AM   #7
bigtoe
here to help
bigtoe's Avatar
D5 m8..i stated this earlier..same as xms4400
Got a question???
Old 02-17-2004, 07:35 AM   #8
bigtoe
here to help
bigtoe's Avatar
http://www.ocztechnology.com/whereto.../north_america for resellers
It uses the same IC as the XMS but we feel a better PCB
Got a question???
Old 02-17-2004, 02:09 PM   #9
the_mei
Which frequency can I expect with at 3-4-4-8 and at 2-3-3-6 with only 2.75V ??
Old 02-17-2004, 02:26 PM   #10
bigtoe
here to help
bigtoe's Avatar
With 3-4-4-8 you may hit 275fsb+ dependant on board and cpu.
With 2-3-3-6 i have no idea as this ram is for high 1:1 overclocking more than low fsb tight timings.It will probably hit around 220fsb or so if i was to guess
Got a question???
Old 02-17-2004, 02:38 PM   #11
eva2000
eva2000's Avatar
here's what 1x 512MB OCZ PC4400 (from dual channel kit) did on AMD64 at 2.88v real vdimm
http://www.abxzone.com/forums/showth...256#post674256
