Old 02-07-2004, 07:35 AM   #1
Jocky
Prescott and Motherboard Support
Found this on PC Stats.
Intel claims that most motherboards will work fine with a BIOS update, which third-party board vendors are expected to release. There's a chance that older Socket 478 motherboards are simply incompatible, though.
How serious is the problem, you ask? We tested a total of eight motherboards, randomly sampled from our test systems, for Prescott compatibility. Of the eight, only three actually worked, including the D875PBZ that Intel sent with the Prescott sample, ABIT's IC7-MAX3, and ABIT's AI7. Those boards that didn't work were ASUS' P4C800-E, AOpen's AX4C Max, two of Intel's D865PERL, and an older D875PBZ.
Although the ABIT IC7-MAX3 and AI7 successfully booted into Windows, neither motherboard properly recognized Prescott’s clock multiplier, in both cases reverting back to 2.8GHz. Each board was flashed to the latest publicly available BIOS, but ABIT clearly has some work to do before touting full Prescott compatibility. Consequently, we weren’t able to overclock the Prescott core at 3.2GHz. The only remaining platform with which to test, Intel’s D875PBZ, is limited to a four percent “Burn-in” mode that doesn’t facilitate aggressive FSB manipulation.
P4 3.0E Prescott @3.6Ghz, P4S800D-E Rev1.04, 512mb Adata DDR450,512mb, 2x80gb Seagate Barracuda7200.7 SATA Raid0, 40gb WD 7200rpm. MSI Ti4200, Liteon 163 DVD, Liteon 48x12x48 CDRW. WATERCHILLED.
Old 02-07-2004, 08:01 AM   #2
Mr Steveo
Stayed @HolidayInn Xpress
Mr Steveo's Avatar
Thumbs up
I believe a couple of people in Sandogs thread (Intel Chipset forum) have Prescotts running fully supported and smooth as silk. So far everyone over there seems happy with the Prescott / D875PBZ Canterwood combo.
Hardware Siggy - Under Construction
Join me on Google+ at
Old 02-07-2004, 05:31 PM   #3
Unless it is a heat/power issue the other boards probably just need to get their BIOS's in order. It doesn't surprise me that the Intel board works. I wonder if the other Intel board was a 206? That wouldn't be nice.
Mr.Steveo, I wasn't aware that anybody in our thread had a Prescott yet. Maybe I missed a post.
Old 02-07-2004, 06:10 PM   #4
pointreyes
So the P4C800E-D is a dead board for the Prescott? This has been one bad day for me so I'm not a bit surprised if this is the case. :sad:
Old 02-07-2004, 06:12 PM   #5
BBThumper
Happy, Joyous and Free
BBThumper's Avatar
......The p4p and the p4c both work with the Prescott now. Its been seen in threads here and Xtreme and O/C forums.......
ASUS M3A32-MVP Deluxe
AMD Phenom 9600
XP-90c w/ a T.T. 92mm fan
2 x 2gig pc26400
Nvidia 8400
2 x Raptors in Raid 0
......My City's moto: Welcome to Philly, now get the heck out!!!!!!!
Old 02-07-2004, 06:13 PM   #6
VSEKH
Fold for ABX
VSEKH's Avatar
Asus most likely will release a bios update soon to enable Prescott support on this board if does not support it already.
Folding Rig:Gigabyte GA-P35-DQ6, QX9650 cooled with a Zalman 9700NT, Powercolor X300SE, Audigy2zs, 4G DDR2-800 Mushkin memory, Plextor PX-760, Pair of 74GB WD Raptors in Raid0 & Seagate 750GB SATA drives, PC Power & Cooling 610 watt PSU, Coolermaster Cosmos case
Gaming Rig: Asus Maximus Formula SE, Intel QX9650 cooled with a Zalman 9700NT, EVGA 8800GTX, 4GB of GSkill DDR2-1000, Audigy XFi fatality, Samsung 203B, Pair of 150GB WD Raptors in Raid0 & 1TB Hitachi Sata hard drives, PC Power & Cooling 750 watt PSU, Coolermaster Stacker STC-T01 case
Old 02-07-2004, 06:18 PM   #7
pointreyes
I sure hope so because I though bios 1014 addressed this and I have a Prescott coming probably by Wednesday.
Old 02-07-2004, 06:19 PM   #8
BBThumper
BBThumper's Avatar
......Prescott has been supported since the 1011 I believe. Look what Fugger found:
http://www.xtremesystems.org/forums/...5&pagenumber=2
Sorry, its half-way down the page.........the Prescott ran alot better on his Asus than Abit......
AMD Phenom 9600
2 x 2gig pc26400
Nvidia 8400
Old 02-07-2004, 06:34 PM   #9
pointreyes
Thanks BBThumper. I will take the risk I guess. I have been hearing that for video encoding that the Prescott really is good for it. However, I'm also hoping that the extra cache will make database preformance better.
Old 02-07-2004, 06:37 PM   #10
BBThumper
BBThumper's Avatar
....the only thing is that they look to run reallllllllly hot so make sure you have a good HSF.......
AMD Phenom 9600
2 x 2gig pc26400
Nvidia 8400
Old 02-07-2004, 07:07 PM   #11
pointreyes
Makes me think of the good ole T-Bird days.
