Old 02-15-2004, 11:48 AM   #1
Rare1_abx
Anyone up for some troubleshooting???
Ok heres the deal. Currrently, I am running OCZ 4000 gold 4x256. Before this I was running 2x256 and was limited to 250fsb with my 2.4c on a p8p800 bios 1014 final. With my new sticks in a 5:4 ratio I was able to make it into windows at 295fsb but was not prime stable. At a 1:1 ratio, I can only run at 250fsb so I believe it is my memory that is limiting me. I am also using a generic starlogic 450w PSU which is possible the problem??? Basically, I am looking for some tips to increase stability so I can run at least 267fsb at a 1:1 ratio. Here are some bios specs (I have tried pretty much every combination). Maybe Bigtoe could help?
This is where I am at (250fsb 1:1) anything more is unstable
Bios 1014
Spread Spectrum- Diabled
Mps Revison- 1.4
Vcore- Auto (have tried 1.525 thru 1.625 with no luck)
ICH delayed- disabled
Usb legacy- disabled
Timings- 2.5-4-4-6
burst lenght-8
vdimm- 2.85
MAM-disabled
Performance mode- Standard
If anyone has some tips that could help I would be very greatful!!!!
Old 02-15-2004, 11:54 AM   #2
PCBruiser
My guess, you need more vDimm, but are limited to what the hardware/bios will let you do. There is a hardware modification for your board that you can do to increase the vDimm you can supply the sticks. If you do a quick search here there are numerous references to the modification articles.
Old 02-15-2004, 12:01 PM   #3
WarpSpeed
Quod erat demonstrandum
Why do you insist on running 1:1 ratio? I think you will obtain much greater overall performance by running the highest FSB possible, especially if you can run stable at 280-285. Unless you run applications that are very sensitive to memory function, the higher FSB will provide much more improvement in performance than will a higher mem ratio. You will need to run your own real-world benchmarks, using your own applications, to see what works best for you.
IS-7, 2.6C @ 3.45GHz, 2GB OCZ PC3200, Antec 500, W2KSP4
Old 02-15-2004, 12:07 PM   #4
Rare1_abx
I will try some more tests at 5:4, but have been having trouble with prime95 (failing after 2min or so). I have successfully played BF1942 for almost two hours, while prime could not make it passed 2min. How importent is being "prime stable". Is there any other programs I should use to test stability besides memtest and prime?
P4P800
2.4c @ 3.0GHz 38C Full Load
OCZ PC4000 Dual Gold 2.5-4-4-6
Volcano 7+
MAM-Enabled
Perfomance mode- Standard
9800 pro
100% Stable!
Old 02-15-2004, 12:09 PM   #5
Rare1_abx
I also don't really feel up to doing a vdimm mod. I don't even own the tools required. Anyone think it could be a PSU problem?
P4P800
Volcano 7+
MAM-Enabled
9800 pro
100% Stable!
Old 02-15-2004, 12:10 PM   #6
PCBruiser
Well, I am not particularly impressed with prime - others will argue that point. If memtest is stable, and you are stable in Windows with intensive things like video rendering, then I would say prime is not all that important. Unless you are experiencing other problems, I don't think it is a PSU problem. But check the voltage readings with Probe, mbm or in the bios.
Old 02-15-2004, 12:14 PM   #7
Rare1_abx
Right now Probe says my voltages are:
12v-12.159
5v-5.053
3.3v-3.392
Vcore-1.584
P4P800
Volcano 7+
MAM-Enabled
9800 pro
100% Stable!
Old 02-15-2004, 12:20 PM   #8
PCBruiser
Then I don't think the issue is PSU related. As I said, I don't think prime is the best test of stability. And if everything else is OK, then your inability to get above 250 is more a vDimm limitation than anything else. I think you could get higher with more vDimm, but I also understand your reluctance to make a hardware modification. Perhaps there is a professional near you who would be competant to do the mod for you. Otherwise, why don't you PM bigtoe, and ask him to take a look at this thread?
Old 02-15-2004, 12:22 PM   #9
Rare1_abx
This is gonna make me sound like a total Noob, but how would I go about PM'ing Bigtoe?
P4P800
Volcano 7+
MAM-Enabled
9800 pro
100% Stable!
Old 02-15-2004, 12:24 PM   #10
PCBruiser
User CP on top of the page. You will find private messages (PM) there. I think he just posted on another thread, so he is around.
Old 02-15-2004, 12:28 PM   #11
Rare1_abx
Thanks PCBrusier!
P4P800
Volcano 7+
MAM-Enabled
9800 pro
100% Stable!
Old 02-15-2004, 12:34 PM   #12
bigtoe
here to help
bigtoe's Avatar
Test your modules one at a time and try each memory slot also.
If you find you have a bad module mail me.
Got a question???
It may have already been answered!!!
Old 02-15-2004, 12:36 PM   #13
Rare1_abx
What settings should I use while testing them? I have never done this before so excuse my ignorance
P4P800
Volcano 7+
MAM-Enabled
9800 pro
100% Stable!
Old 02-15-2004, 12:41 PM   #14
gaddster
Having fun...
gaddster's Avatar
use the spd settings to start with as you have the golds.. ie 2.5-4-4-7
I have the same RAM and they need 2.95 to be memtest stable at 500ddr 2.5-4-4-5
Anything over 520ddr and they needed over 3v. Had them up to 560ddr at 3.15v but not for long even though they have a fan over them.
Asus P4C800E | 730 Dothan | 6800GT | GSkill LA | OCZ 520w
Old 02-15-2004, 01:04 PM   #15
bigtoe
here to help
bigtoe's Avatar
Test using spd timings and 2.85v max...run memtest or goldmem on them for atleast 1hr each...I loop test 5 100passes as this generally heats up the ram pretty good and shows any weakness.
Im going to move this thread to the memory forum as i do feel it is memory related.
Got a question???
