Old 09-09-2001, 12:57 PM   #1
steveg
Will an old Celeron run in a CUSL2-C?
I was trying to get an old machine running (which had a dead mobo) with a spare CUSL2-C. The cpu is an old Celeron - I think a 300.
Would you expect it to work? As it is, I don't even get any bios beeps and as I know the mobo works I can only assume it doesn't like the cpu.
Am I right? If so, whats the cheapest current Celeron which will go in this board?
733?
Steve
Old 09-09-2001, 02:00 PM   #2
JeffMD
Otaku
JeffMD's Avatar
I recall the cusl2-c dosnt work with any celerons at all.
Old 09-09-2001, 02:28 PM   #3
Rebellion
Iīm runnin my CUSL2 with an 800MHz celeron just fine.. i even got it to 1333 and it didnīt make any trouble at all so the new celerons will work at least.
//Rebellion
Celeron 800 @ 1333 MHz @ 2.2v (wiretricked), Watercooled
Asus CUSL2
384 Mb Mosel Vitelic PC133 cas2 memory @ 166 MHz cas3
Asus v7700 Geforce2 GTS Deluxe
IBM Deskstar 22GPX 18Gb 7200 rpm
Pioneer DVD-103
Enermax EG351P-V 330W
www.gavle.to/rebellion/puter.html
Old 09-09-2001, 03:12 PM   #4
Miles
Hi Rebellion,
The CUSl2-C only supports FC PGA Celerons...it will not support any other architecture...
Miles
________________________________
Intel 4690k| ASUS Z97 sabertooth| 16GB Kingston DDR3|ASUS GTX 970|Samsung 850 Pro 512GB SSD | 1 - Seagate 2 TB Barracuda ES | Seasonic 650 watt Gold PSU|Fractal Design Arc Midi rev 2| Windows 7 64-bit Professional | Eizo CX-241
Old 09-09-2001, 03:28 PM   #5
steveg
Miles...
I'm not an expert on this!
The Celeron I've got fits in the socket - does this mean it's an FC PGA?
S
Old 09-09-2001, 04:02 PM   #6
Rebellion
Yeah.. I thought so too.. but wasnīt completely sure as i have never tried with the old celeron so i decided not to write about it (-:
//Rebellion
Asus CUSL2
Pioneer DVD-103
Old 09-09-2001, 11:10 PM   #7
dddibley
Time well wasted
dddibley's Avatar
Same number of pins on the PPGA and FC-PGA, although the pin-outs are apparently different. CUSL2 will run PPGA (<=533) and FC-PGA.. CUSL2-C is FC-PGA only. I believe it has to do with power requirements.
The Celeron (PPGA) and Celeron II (FC-PGA) both come in 533 Mhz versions. Make sure you get the right one.
ddd
Old 09-10-2001, 03:36 AM   #8
steveg
Thanks ddd,
I guess the one I've got is PPGA not FC PGA which probably accounts for why nothing happens.
S
Old 09-10-2001, 07:47 PM   #9
dddibley
Time well wasted
dddibley's Avatar
Know how you feel. Was going to plop the old 400 in this one after I upgrade.. but for the price of a low end Celeron II (US$45).. why bother. Maybe I can find a good LX board cheap somewhere?
ddd
Old 09-18-2001, 09:54 AM   #10
Tranced_abx
Who, me?
Tranced_abx's Avatar
My Celeron 500 PPGA SL3LQ ran fine @600 on my CUSL2
Don't know the difference (except for the onboard video) between a 815-E (CUSL2) or a 815-EP (CUSL2-C) I got them both overhere... both o PIII Coppermine @ this moment
Intel S-Spec
Laptop:
P4 3.2/800 HT
1Gb DDR400
60gb 7200rpm
Server:
Asus S-Presso
P4 2.8/800 HT
512MB DDR400
250GB SATA
