Old 09-25-2001, 05:31 PM   #1
Efrain
Question Memory capacity on CUSL2 (no audio)
I know this should be in the Memory section but I guess more people access this forum! :-)
I have a CUSL2 mobo with NO AUDIO... I had a 256MB PC133 stick on the mobo and today I bought (2) 256MB PC133 sticks for it, so I could bring the RAM up to 768.... BUT!!! The manual says it only accepts up to 512MB!!!!! Is there a way around this or do I have to go back to my Tyan Trinity 400 mobo so I can use all the memory I have now??
Thanks in advance!
I have Bios 1008 flashed..
Efrain
_________________________
PIII-700E
256MB PC133 Princeton
ASUS CUSL2
300W Power Supply
Elsa Gladiac GeForce 2 GTS 32MB
Maxtor 15.2GB 7,200RPM ATA66
HP CDWriter+ 8200i CDRW
SoundBlaster Live! MP3+
Diamond SupraMAX 56K
HP Deskjet 840C
WinME
Old 09-25-2001, 06:38 PM   #2
dddibley
Time well wasted
dddibley's Avatar
512MB only. i815 chipset limitation.
Not sure about WinME, but any lesser Win OS wouldn't be able to use the extra mem anyway (512 cap).
ddd
Old 09-26-2001, 11:17 AM   #3
JungleJim
Yup, 512MB is the limit for any Intel 815 based mainboard.
As for Win9x not being able to handle more than 512MB, that's not entirely true: there is a bug in Win9x (and Me, BTW) that prevents Windows from using more than 512MB of memory correctly. You can solve the problem by limiting the amount of memory Vcache uses. See this MS KB article for more info.
HTH
For system specs, see profile.
Old 09-26-2001, 04:45 PM   #4
dddibley
Time well wasted
dddibley's Avatar
Interesting read.
ddd
Old 09-27-2001, 01:48 AM   #5
Cool
Thanks for the reference JungleJim.
