Old 11-17-2005, 01:58 PM   #1
polonyc2
Legacy
polonyc2's Avatar
Asus A8N32-SLI Deluxe thread
the latest motherboard from Asus is finally hitting retail shelves after a lengthy delay...apparantly there were a few problems with the 1.01 revision board that caused the delay in availability in stores....according to Asus the "slight issue" has now been fixed with Revision 2.0
Intel i7 980X (Gulftown)
***** Noctua NH-U12P SE2
G.Skill Falcon I 256GB SSD
Lian Li PC-A70B (black)
***** Corsair HX850W
Lite-On IHAS424
***** NEC 2490WUXi LCD
Windows 10 Home 64-bit *****
Old 11-18-2005, 05:00 PM   #2
lowdog
And just to set the records straight. All of the above quote is BS!
Rev 1.01 is the ONLY board in production and the only board shipping. There is NO rev 2.0 board at all.
Old 11-18-2005, 05:19 PM   #3
polonyc2
Legacy
polonyc2's Avatar
yes apparently someone spotted a picture of a Revision 2 board on the X-Bit Labs website with the caption "Two ASUS EN7800 GT Dual graphics cards on ASUS A8N32-SLI Deluxe Revision 2 mainboard" and ran with a false story about a Revision 2.0 board...a lot of sites picked up on this and this rumour started spreading...I'll be getting my board next week and will check the Revision but as of right now it looks like 1.01 might be the only version out...
attached is a pic from the X-bit Labs article that started all the fuss...
http://www.xbitlabs.com/news/video/d...108220829.html
Lite-On IHAS424
Old 11-18-2005, 05:25 PM   #4
lowdog
I have this board and it's a rev 1.01. A lot of people are receiving this board atm and all are rev 1.01.
I advise to run the fan unit that comes with the mobo on the copper radiator for the heatpipe even if you are using a regular heatsink/fan on the cpu. This helps keep the mobo temp down.
I'd also flash straight to beta bios 805 as this seems a better bios than the official 703.
Board is stable with rock solid Vcore at stock setting with an X2 4800 and 1 7800GTX 512meg card atm. Getting a second 7800GTX 512meg in a couple of weeks.
Old 11-18-2005, 05:38 PM   #5
polonyc2
Legacy
polonyc2's Avatar
thanks for the tip on the fan...I'll do that
I read that some people were hesitating to flash to the 805 BIOS because of something in the ReadMe about it lowering your FSB at full load or something similar to that
Lite-On IHAS424
Old 11-18-2005, 06:05 PM   #6
lowdog
Sounds like more conjecture to me. There is no readme for the 805 bios as it's still beta.
Edit: Nah that BS, just tested it. Ran cpuz and dual instances of prime95 and fsb stays at 200MHz. So it's nothing to worry about. Wonder where all this crap comes from.
Old 11-18-2005, 06:43 PM   #7
alien resident
a xeno..what ??
alien resident's Avatar
you plan on having PCi cards in there and if so have you considered the space issue ?
My Rig AMD FX-60 | Asus A8N32-SLI Deluxe | 2x1Gb Corsair XMS 3500LL Pro | 2X Asus 7900 GTX in SLI | OCZ 600W PSU | Koolance EXOS-1 with CPU-305-V06 Block | Razer Copperhead Chaos with eXactmat
My Laptop
USED Alienware Area-51 : Intel P4 1.8 Ghz | Intel i845M mobo | 2x512 Corsair | ATI Mobile 7500 Radeon | Samsung 100Gb HD | Dual boot OS : XP Home & Ubuntu Linux | Razer Diamondback
Wife's Rig
Intel P4 3.4c @ 3.6 Vcore 1.5625v | Kingston HyperX 1 Gb (512x2) DDR434 2.5,3,3,7 Vdimm 2.8v | Gigabyte GA-8KNXP Rev 2.0 FH BIOS | WIN XP Pro Sp 2 | Powercolor X800 XT PE | SB Audigy 2 ZS | 36Gb Raptors X 2 RAID O 128k Stripe | Liteon 52X/16X CD/DVD ROM | Antec True 550W PSU | MSI Floppy |
Old 11-18-2005, 07:18 PM   #8
lowdog
Yep all considered. 2 x7800GTX 512meg and a Creative Audigy2 ZS fit no probs.
Old 11-18-2005, 07:20 PM   #9
polonyc2
Legacy
polonyc2's Avatar
I'm planning on having 1 GTX 256 card with the Zalman VGA cooler, 1 X-Fi sound card and a modem...will there be enough space for all those?
and later on will I be able to add a 2nd video card?...I'm thinking I'll be able to add a 2nd video card but without any cooler correct?
Lite-On IHAS424
Old 11-18-2005, 07:24 PM   #10
lowdog
I'd just stick with the reference cooler for the 7800, it does the job fine.
Old 11-18-2005, 07:26 PM   #11
polonyc2
Legacy
polonyc2's Avatar
but in terms of space I'll be OK correct?...so if later on I added a 2nd GTX card and used the reference cooler then I also would be fine?
Lite-On IHAS424
Old 11-18-2005, 10:59 PM   #12
djt
lowdog,
How did you get two 7800GTX/512 cards in with the sound card? Im running two 7800GTXs with an X-Fi Fatal1ty FPS sound card and there is just barely enough room for air flow for the video card occupying the top PCI Express slot. Here are some pics of my build with the clearance issues-
http://www.abxzone.com/forums/showthread.php?t=99117
ASUS Rampage III Extreme (1005 BIOS)
Intel Core i7-980X Extreme Edition w/Corsair H70
Corsair DOMINATOR-GT 6GB DDR3 1600 (PC3 12800) CMT6GX3M3A1600C7
EVGA GeForce GTX 480 SuperClocked (260.99)
Creative Sound Blaster X-Fi Titanium Fatal1ty
WD VelociRaptor 150GB Windows 7 Ultimate 64
WD VelociRaptor 300GB Games/Programs
Corsair AX1200 Watt
Corsair 800D w/NoiseBlocker fans
ASUS Rampage II Extreme (1802 BIOS)
Intel Core i7-975 Extreme Edition w/Thermalright Ultra-120 eXtreme 1366 RT
Mushkin Redline Ascent 6GB (3 x 2GB) DDR3 1600 (PC3 12800) (6-7-6-18-1N)
Asus/ATI 5870 (Catalyst 10.10)
WD VelociRaptor 150GB Windows XP/SP2 64-bit Edition
SILVERSTONE 1500Watt SST
SILVERSTONE TJ09-B
Old 11-19-2005, 08:52 AM   #13
Blue078
BB Stacker
Blue078's Avatar
Subscribe. Keeping an eye on this board
DFI SLI-D r.AA0...BIOS 702-2...3700+...7800GTX...2x1g Ballistix..PCP&P 510SLI ...Creative XFi...Promedeia Ultra 5.1's...2005FPW...Cooling by Prometeia and Thermaltake
Old 11-19-2005, 09:08 AM   #14
FB
me too, i might ditch my DFI
Old 11-19-2005, 02:56 PM   #15
Blue078
BB Stacker
Blue078's Avatar
One of the guys at XS has the board up and runing Looks promising so far. Now if I could ever catch them in stock I'll be set.
http://www.xtremesystems.org/forums/...ad.php?t=80491
